3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Original XBox Controller Memory Card Slot USB Conversion
This Instructable is a stand-alone, as well as a companion to another Instructable that i have to do an easy Softmod to your Original XBox without needing a Memory Card or Action Replay. Keep in mind that the Memory Card made by Microsoft is a FAT16 Device, but has 8 Megabyte Limitations. After doing this to my XBox controller, i was able to easily use a Kingston DataTraveller 4 Gigabyte USB stick with ease. This is also handy when you are limited to One Controller/Breakaway combo, like i am, and need to be able to transfer your files and interface at the same time with the XBox.
Credit for the Pinout diagram goes to Mike Chambers (who made a Memory Card to USB Adapter, but i simply cut out the middleman and hardwired the USB port directly into the controller!) his project can be seen at: http://mesh.typepad.com/blog/2005/01/creating_a_usb_.html
Another helpful resource for anyone undertaking any project using USB will appreciate this site:
http://pinouts.ru/Slots/USB_pinout.shtml This site gives some good visual guides on most things USB (even lists iPod and other proprietary connectors).
Step 1Shopping List
Shopping List
Small Philips screwdriver
Soldering Iron (I used a cordless one)
Glue Gun
Solder
Flux
Utility Knife
Small Needle Nose Pliers
USB Extension Cable (mine is a dollar store one that cost $1.50)
XBox Controller (S Model is my preference)
Additionally, some experience soldering, as well as stripping wire, and a delicate touch is helpful.
107 comments
1-40 of 107next »
Dec 19, 2010. 8:15 PMTheodore155 says:
my usb blinks once and then nothing happens on the xbox
Nov 13, 2011. 1:42 AMmiksnake says:
Thanks for this instructable, I really appreciate it and am looking forward to getting it working.
I followed all the instructions tonight to modify the controller (used a Hip Gear one instead of a Microsoft, but it looked very similar inside). I used a Kingston Data Traveller 4 GB memory stick.
My problem is when I put the flash drive in and go to memory on the Xbox, the screen kind of flashes and makes a blinking sound. The green LED on the flash drive comes on and flashes in sync with the TV.
Is there any way to know whether this is a memory card compatibility issue or a wiring mishap?
Thanks.
by the way, once I've gone through this and your other tutorial on the softmod, how do I take all my games and make digital copies so I don't need to use the actual discs anymore?
Nov 26, 2011. 9:08 PMMyGhost says:
Do you have to use a 1.1 port port or would it be possible to use a High Speed 2.0 port?
Dec 23, 2011. 10:16 AMbarguellez says:
can i use electical tape instead of soldering??
Sep 24, 2011. 12:34 AMcooldoodtekk says:
Quick Question, Can I use a thumb drive as a memory card with this? Sorry I am fairly new to xbox modding, but I am think of purchasing one and trying.
Sep 18, 2011. 10:02 PMToddimyre says:
This is a pretty nifty trick. You can also do something similar with modified Xbox controller cord to USB extension. Basically, you cut the end off a controller that's broken, add a USB extension, and plug in any flash drive. ;-)
Jul 30, 2011. 9:18 PMrholland1 says:
How do you know which usb drives work?
I know i got the thing right, but my sandisk cruiser doesn't
May 1, 2011. 4:49 PMxbulldog670 says:
Thanks man, it works great. I made my female usb cord about 8 inches long, because i didnt have any hot glue and plus i just kinda liked it like that. So i stuffed the memory card slot with packed tight cotton balls so the cored wont wiggle and pop the wires off of the board. Then I took black duct tape, and taped the entrance to cover up the cotton balls, it looks really nice. Deffinetly recommending this tut to others!
Mar 19, 2011. 2:49 PMSpotman says:
scratch that i did mess up
i failed to save the wires on the usb and end up soldering them backwards
Mar 19, 2011. 2:42 PMSpotman says:
i think id mess up somehow but my controller nearly caught on fire
Mar 4, 2011. 5:34 PMEncomb says:
Could you use a usb card reader instead of a flash drive?
Dec 22, 2010. 4:02 PMMrHanimi says:
Do the wires just have to be soldered into the holes?
or is there somewhere on the other side of the board they need to connect to?
I honestly don't know whether this is a stupid question :s
Dec 23, 2010. 3:21 AMdushii says:
I have soldered well same as in the tutorial but i don't use a kingston usb I use JetFlash Transcend 2gb. And in the screen on xbox at the memory When I go the it makes again that problem make a sound bleep bleep and the light of the screen goes up and down the some as the sound which it makes bleep bleep and doesn't show anything only xbox hard drive. If you want a video to show you the problem I can show you just tell me if you want
Dec 23, 2010. 8:31 AMMrHanimi says:
I don't know why you posted this as a reply to my comment
but your memory stick probably isnt supported
just try another one from around the house
you are using an original xbox arent you?
does not work with xbox 360
Dec 23, 2010. 9:23 AMdushii says:
of course I'm using an original xbox but i check the list of the device and my device is in the the device that don't work
Dec 23, 2010. 11:37 AMMrHanimi says:
have you tried a different usb stick?
Nov 26, 2010. 8:48 AMdushii says:
can anyone help me i have did your mod but when I plug in a usb it want recognize and when i got at memory on xbox is nothing and the usb light goes on
but then when i go to the memory blade, the screen flashes and makes a bleep bleep sound please help me
Dec 11, 2010. 9:55 PMremorsedhacker says:
this was the worst part omfg
Dec 11, 2010. 7:41 PMremorsedhacker says:
i think he was talking about the ''caps'' but im still on the cutting plastic step lol
Oct 22, 2010. 1:36 PMrafaelmotas says:
Great Tut. Just made the mod and works like a charm.
Thax sooooooooo much! Now I don't have to buy a memory card to mod my xbox!
Oct 23, 2010. 9:43 AMrafaelmotas says:
Yes I've seen it and I'll follow it to mod my xbox. I'm just waiting for the slinter cell game to arrive. I can't wait to mod my xbox!
I've just one question: Can I copy a xbox rom to my usb drive and then copy it from the usb drive to xbox to play the game from the xbox hdd?
Oct 25, 2010. 5:07 AMrafaelmotas says:
Ok. Maybe I'll do that. thanks
May 27, 2010. 12:18 PMTreborabc says:
If you do this you can still play games with your controller, right?
May 27, 2010. 7:18 PMTreborabc says:
half the time it tells me it it not functioning, and my computer has to format it. Help?
Oct 12, 2010. 9:52 PMsorahypernoize says:
Do I, like, need a driver for the thumbdrive? Cos it worked fine with my XBox, but I can't transfer files to my xbox...
1-40 of 107next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:daiatlus79
techie who believes in making things that i own do what i want or what they were intended to do!
