loading
Step 5: Wiring and Installation of USB Socket
Take a piece of tape and wrap around the metal USB Socket. I used masking tape, as the purpose of this is to keep hot glue from seeping into the socket. Now glue the rear of the socket into the bottom part of the Memory Card assembly. Make sure to glue up the end of the socket so that the wires are covered up into the insulation of the wires. This will ensure the wires will not do any excess bending and will not snap off. On the inside of the assembly, run a small bead of hot glue on the top and bottom sides of the socket. Wetting your finger tip immediatly after and smoothing the bead will make this smooth and flush (it is a bit hot but you should not burn yourself). Let this all cool for a few minutes to make sure that the Socket is straight.
Now to do the next step will require some soldering, so make sure to be careful to not burn yourself. In the wiring guide enclosed, you will see an explanation behind the five pins. The yellow wire is almost never needed for any reason other than accessories, and is not necessary to this project so that hole will not be used. The wires have to be inserted in from the bottom, which is the same side as the socket that was removed. A good starting point is to have the Green wire soldered to the center hole. Make sure to use some Flux (i spread mine with a paper match end), and extra fine solder. An easy way to know what wire goes where is the following: (with the triggers pointing up) Red White Green Empty Black. The wires should be soldered in through the top of the board, where the other socket remains. Then run some glue along where the wires feed in to keep the wires from snapping off from the board.
great little project thanks
<p>Done <br> this and windows recognizes the drive but doesn't seem to have enough <br>power to power-up the drive. Windows pop-up the message &quot;hub exceeds <br>power-limit&quot;. Also the drive runs at USB 1.1 (read this too late in your <br> article). What can I do about this?</p><p><br>I have made another mod in <br>the past with a &quot;speedlink stormtrooper&quot; and build in a USB-drive and a <br>logitech mini-USB 2.0 Hub. The controller is connected to this mini-hub <br>and also the usb drive. This works perfectly, I think that's a better <br>idea. You can also use the two other usb connections.</p>
<p>Note: When I made the first one I didn't know there was a hub inside the controller ;-)</p>
<p>You guys know you could just buy a Phantasy Star USB adapter instead? Granted these might be hard to come by nowadays. </p>
<p>Thanks for the info, didn't know they existed. I've only just managed to work out you can use USB devices this way, and via the XboxController-to-USBFemale method. This post was very helpful.</p>
<p>Hey Peter, I've looked and looked--and would rather have one of these instead of a cable--but I've had no luck finding these? Any advice? I'm in the U.S.--I've even tried searching eBay for entire PSO-for-XBOX original 'kits'...thanks.</p>
So if I have understood this right, you can just cut a xbox controller cord and add a USB female jack to that. So as I have five xbox controllers (of which one is a bit broken) I'm going to add a male USB jack to the controller end, and then I have it unpluggable, but still working! Now I just need to find out which one is broken of them five...
Another video of mine this time an xbox console mod complete with usb ports emulators and roms...Modded Xbox with usb ports and Emulators...My Sprayed and Modded Original Xbox running Xbox media center with usb ports and Emulators. <br> <br>http://youtu.be/-9UtSi9PRew
just completed my latest controller mod...i know it not an xbox controller...but just wanted to show it off lol!!...wanted to say thank you for the inspiration which has inspired me to do this heres my latest controller mod...16GB USB Joypad Mod with 4793 games on it...Old usb Joypad modded into a plug &amp; play video gaming unit that allows you to play every one of the 4793 games that are already integrated into the joypad ...From Arcade Games to Atari2600 games to Sega Master System Games to Sega Mega Drive Games to Super Nintendo Games to Nintendo64 Games...For use with any desktop pc or laptop running windows <br> <br>Modded USB Joypad with a 16GB internal memory implant with 4793 games on it that Include (1619 Arcade Games)+(722 Atari2600 Games)+(370 Sega Master System Games)+(987 Sega Mega Drive Games)+(775 Super Nintendo Games)+(320 Nintendo64 Games) <br> <br> <br>..I would have listed all of the games for all the Consoles (1619 Arcade Games)+(722 Atari2600 Games)+(370 Sega Master System Games)+(987 Sega Mega Drive Games)+(775 Super Nintendo Games)+(320 Nintendo64 Games)...But there are far to many to list as it is very time consuming <br> <br>ENJOY. <br> <br>http://youtu.be/mVWdXpSBxY4
This mod is an upgrade to the Xbox To USB Controller Mod with 2GB internal removable USB Flash Drive with 153 games....Xbox USB Controller Mod (UPGRADE) with a 4GB internal USB Flash Drive with 355 games <br>http://youtu.be/8rMSRI2EIAA <br>
Nice Mod iv finished modding my xbox controller with an added upgrade Iv modded the end of this old Xbox controller to a male usb for use with any laptop or pc iv also gutted out a memory port down to the pins and soldered and hot glued in a female usb replacement into the empty port then i added a micro sd card reader with a 2gb sd card which iv added 153 arcade games onto into the usb port then i configured all the Xbox controller buttons and finally gave it a nice blue stray job. <br> <br>Xbox To USB Controller Mod with 2GB internal removable USB Flash Drive with 153 games Part 1 <br>http://youtu.be/0j8t0kYO6d0
I'm gonna do this but in a different way. Gonna put the USB drive into a memory card casing since I have a Game Shark USB adapter. Keep it original looking with 4 GB of space. Inscrutable to come sometime soon.
good idea! post pics when done :) or instead of a usb thumbdrive, put an SD card reader in it so the memory card is a card reader and makes it upgradable :)
Sorry to take so long to reply. Life... <br>I ended up not putting a USB drive in the memory card when the Xbox had issues with it. (Read it fine at first then quit. ???) So instead I made it into a USB adapter. Plug memory card into controller and USB device into the card. I have instructable written for making one along with demo video of it in action with a 1GB 3.5&quot; HDD connected through a IDE to USB adapter. Xbox picks it up no problem.
I discovered my HDD to USB adapter works with my Xbox. I now have a 3.5&quot; 1 GB IDE HDD &quot;memory card&quot; and a 1.44 GB 2.5&quot; IDE HDD &quot;memory card&quot;. Both running through my no name IDE and SATA to USB adapter. Video of it in action in my Instructable for my memory card USB adapter.
So my idea of a 4 GB memory card died when the USB drive decided to be stupid. So instead I made memory card to USB adapter complete with Instructable. Check it here: <br>https://www.instructables.com/id/Xbox-USB-memory-card-adapter/ <br>I thought I was first to do this but looks like I'm the second...
just completed the above process for myself, many thanks for the guide! <br>
If you do this you can still play games with your controller, right?<br /> <br />
yup!
yup
Do you have to use a 1.1 port port or would it be possible to use a High Speed 2.0 port?
this will only be a 1.1 port as the Original Xbox never had USB 2.0 capability
I bought a xbox 360 usb extension cable(yes i am aware that this is an original xbox thread) and cut it open; the wiring is identical to the wiring diagram that you provided in this instructable. Does this mean that my cable would be compatible? I am unsure if it is 2.0 or 1.1
should be
Here's my situation: there are no USB 1.1 cables in my area. USB 2.0 has become the norm and USB 3.0 is on the way. I bought a used Xbox360 extension cable and split it open; I am unsure if it is USB 1.1 or 2.0, but it has the exact same color coded wiring as the 1.1 USB. My question is, will this work? I can post a link for a picture for clarification if needed.
the cables are all the same. go for it. the cables themselves do not determine the version in pretty much any case.
my usb blinks once and then nothing happens on the xbox
check compatibility of your drive: not all are compatible. a simple Google search will reveal if it is or not
Thanks for this instructable, I really appreciate it and am looking forward to getting it working.<br><br>I followed all the instructions tonight to modify the controller (used a Hip Gear one instead of a Microsoft, but it looked very similar inside). I used a Kingston Data Traveller 4 GB memory stick.<br><br>My problem is when I put the flash drive in and go to memory on the Xbox, the screen kind of flashes and makes a blinking sound. The green LED on the flash drive comes on and flashes in sync with the TV. <br><br>Is there any way to know whether this is a memory card compatibility issue or a wiring mishap?<br><br>Thanks.<br><br>by the way, once I've gone through this and your other tutorial on the softmod, how do I take all my games and make digital copies so I don't need to use the actual discs anymore?
1. your flash drive could have a chip set that isnt compatible with the Xbox <br>2. a bigger hard drive and a dvd copier program would be the solution to your issues. installing a larger hard drive with a soft mod is tricky.
can i use electical tape instead of soldering??
how will you get the wires to make and maintain contact to the board, usb socket, etc?
Quick Question, Can I use a thumb drive as a memory card with this? Sorry I am fairly new to xbox modding, but I am think of purchasing one and trying.
yes as long as it is compatible, you can. there are compatibility lists online
This is a pretty nifty trick. You can also do something similar with modified Xbox controller cord to USB extension. Basically, you cut the end off a controller that's broken, add a USB extension, and plug in any flash drive. ;-)
i know that, but read in my tutorial: i only had the one controller at the time, so doing that would have been hard to do. could not do that and select the files to move them from the thumbdrive to the xbox with no controller connected lol
How do you know which usb drives work? <br>I know i got the thing right, but my sandisk cruiser doesn't
its a bit of a dice roll. some work and some dont. there are lists online that give compatibility.
Awesome man! This prompted me to pick up The Box at a local Flea. Took me about 30 minutes to open the controller up and finish. Gave me a chance to clean whatever filth was in the used controller. Eeeeew. Works without a hitch though! Thanks for the tutorial! A+
...And the pictures.
sweet.. yeah i think the controller you have is slightly different from mine.. maybe a newer model S... and yeah.. i got the idea on a hunch.. i knew that the controllers were just glorified USB controllers (i have a MadCatz version modded for use with my PC), so i looked up and read about the cards they used. they were just really 8 meg thumbdrives. they even had all the same pinouts as regular USB. so i thought 'screw it.. its worth a try'. and it worked like a charm. i needed it for modding the xbox cause at the time i only had one controller. got 4 now.. and working on taking my Wireless MadCatz controller and putting on a rapidfire mod for it, but i need a few parts for it (got the buttons, just need a few electronic components).
You've turned one of these into a USB controller for a PC? Do you have a tutorial for doing that at all? I'd love to do that...Would make a nice cheaper MS controller, I'd rather dish out $15 for one of these...than $55 for the PC MS controller on the market now. It defiantly looks better and is obviously more efficient. Is there a way to play home brew .ISO files off of the thumb drive through the controller? or perhaps be able to dump onto the Hard Drive in order to play it? Is there also a way to install a larger Hard Drive?
look up modded xbox controller usb. mine should be the first one that comes up (the most hits)
i would rather play things over the hard drive or network.. the USB is slow (USB 1.1). but its worth a try.
yes. i have a video tutorial on Youtube.. i will post it on here soon. look up my username on there.. as well you can look up &quot;xbox controller usb mod&quot;.. i am usually the first hit. i walk you through it and as well ii even provide links for drivers.. and it is not a difficult mod.. and it only will cost maybe two bucks.
I wanted to add...in Step 4...you said &quot;The plastic should just come off the underside,&quot; talking about the plastic card reader port. My two pieces were actually attached by two screws, which needed to come out first...before I could get this fully removed. That was the only confusion. Obviously once the screws are removed, there is no issue.
Thanks man, it works great. I made my female usb cord about 8 inches long, because i didnt have any hot glue and plus i just kinda liked it like that. So i stuffed the memory card slot with packed tight cotton balls so the cored wont wiggle and pop the wires off of the board. Then I took black duct tape, and taped the entrance to cover up the cotton balls, it looks really nice. Deffinetly recommending this tut to others!
scratch that i did mess up<br>i failed to save the wires on the usb and end up soldering them backwards
pinouts.ru is always a good site to go to when wondering about wiring up usb. its a great help
i think id mess up somehow but my controller nearly caught on fire
About This Instructable
222,727views
62favorites
License:
Bio: techie who believes in making things that i own do what i want or what they were intended to do!
More by daiatlus79:Raspberry Pi/RetroPie Project - Part 1 - Getting Started/Up And Running/Rom copying via  Samba Raspberry Pi/RetroPie Project - Appendix 1 - Installing/Using 1st Gen Xbox/360 Wired USB Controller for use with RetroPie EasyCap DC60 (STK1160) + VLC + Xubuntu 13.10 = OpenSource Video Capture!!
Add instructable to:
