This particular slab is actually for aesthetics only, You can making this for stepping on, you just need to apply a couple of inches more thickness than I did and add a bit of chicken wire.
You will need:
Cement
Sand (I used soft as opposed to sharp sand)
A leaf
Water
Bucket
Trowel
Suitable flat surface - thick cardboard if you're not going to move it, I used the top of an old desk.
Knife for opening bags if you need it
Gloves/other general safety gear as appropriate.
Screwdriver or similar sharp pointy implement for getting in crooks and crannies.
Minions - This time I needed a couple of minions/friends/assistants about to take photos and assist with general jobs. You'll probably need a hand when doing this.
As usual having researched the project and not finding anything like it on instructables, the robot links it directly to someone who's done exactly this, but with some neat ideas. You can see it here
Remove these ads by
Signing UpStep 1Picking a leaf
I used a rhubarb leaf as it's in abundance at this time of year, but you could use all sorts.
I'd use a large enough leaf you could step on.
*no minions were injured in the leaf picking process
Also went to a local concrete place and bought some reinforcing fibers - a 1 lb. bag goes a long way and a pinch mixed into the water for each batch of concrete adds a lot of strength to the batch.
Your paving slabs looks amazing, I have to give this a go. When I do i'll post photo. ......... <(•¿•)>
