3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ornamental paving slabs
There's so many boring paving slabs out there and I thought I'd have a go making my own for my allotment.
This particular slab is actually for aesthetics only,  You can making this for stepping on, you just need to apply a couple of inches more thickness than I did and add a bit of chicken wire.
You will need:
Cement
Sand (I used soft as opposed to sharp sand)
A leaf
Water
Bucket
Trowel
Suitable flat surface - thick cardboard if you're not going to move it, I used the top of an old desk.
Knife for opening bags if you need it
Gloves/other general safety gear as appropriate.
Screwdriver or similar sharp pointy implement for getting in crooks and crannies.
Minions - This time I needed a couple of minions/friends/assistants about to take photos and assist with general jobs.  You'll probably need a hand when doing this.
As usual having researched the project and not finding anything like it on instructables, the robot links it directly to someone who's done exactly this, but with some neat ideas.  You can see it here
Step 1Picking a leaf
Picking a leaf
You'll need a fairly big leaf.  I'd avoid leaves such as giant hogweed as the juice will burn you if you're in the sun.
I used a rhubarb leaf as it's in abundance at this time of year, but you could use all sorts.
I'd use a large enough leaf you could step on.
*no minions were injured in the leaf picking process
17 comments
May 21, 2012. 5:38 PMCambenora says:
If you want a really big leaf, and I mean big, try Gunnera Mannacata.
May 10, 2012. 6:24 AMcammy1345 says:
Try spraying the leaf with cooking oil before putting the concrete on.
Feb 7, 2012. 7:11 PMinanobot says:
great!!!
Mar 3, 2011. 9:30 AMbikerchick13 says:
Love it!! can't wait til summer to try this!
Nov 22, 2010. 11:21 PMmaltesergr8 says:
Very cool looking!! Thanks for the great 'able!
Nov 7, 2010. 5:11 PMgeorgiapeach773 says:
This looks great. I think you could add a wooden frame around it (mold) and once it had set up a bit, fill in around it (but not on it) with sand, then fill in the square with more cement with some reinforcement in it, to end up with the square thicker slab with the leaf in relief. Then you could add them in randomly with your pavers in your patio.
Oct 21, 2010. 2:29 AMafridave says:
really nice and very simple, thanks. have no idea where to get such a large leaf though.
May 31, 2010. 12:11 AMbeackmaniax says:
really good instructable, five stars really !
May 30, 2010. 7:43 AMzascecs says:
Very cool.
May 17, 2010. 4:26 PMTSC says:
Nice I'm going to give it 5stars!!!!!!!!!!
May 13, 2010. 8:22 AMDiannaLynne says:
I've made rhubarb leaves for pavers and decorative use as well,  and leave the leaf on during the curing process, which helps keep the cast moist as well.  Eventually it dries up and can be removed easily,  and the remnants can be blasted off with a strong water jet.  Be sure to pack enough material around the large veins to avoid weak spots in the piece.
Also went to a local concrete place and bought some reinforcing fibers - a 1 lb. bag goes a long way and a pinch mixed into the water for each batch of concrete  adds a lot of strength to the batch.
May 6, 2010. 5:40 PMPippaD says:
I need to make pavers for my garden; what a terrific idea!  Ta!
May 2, 2010. 6:30 PMLongmorn says:
Spray some nonstick cooking spray for leaf removal and color with add in concrete color (will never peel off).
May 2, 2010. 12:09 PMkenbob says:
Would love to see the finished product / deployment.   could you used the leaves to "imprint" in a layer of thinset on top of a sidewalk?
May 2, 2010. 9:41 AMCulturedropout says:
Neat!  That's a *huge* leaf!  It might come off better if you dumped some scalding hot water over it to soften it after the concrete is set.  You might be able to just hose it off with a jet of water after that.
May 2, 2010. 8:04 AMNutandBolt says:
Your paving slabs looks amazing, I have to give this a go. When I do i'll post photo. ......... <(¿)>
May 2, 2010. 6:56 AMRadBear says:
Cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
73
Author:tim_n(Visit my Site!)
Hi, I'm Tim. I work on the railways during the day, run a scout troop and have a blog (see above website link) where I discuss my allotment and projects!
