Oscilloscopes are useful for looking at very fast changes in voltage over time, things that we could not measure with a multimeter. Usually when you make a measurement with an oscilloscope, you will see a line that stretches from one side of the screen to the other; this line is actually a graph of voltage vs time (fig 2), where voltage is measured along the y axis and time along the x.
Oscilloscopes come in two varieties: analog and digital(I'll be using a digital scope in this tutorial). The controls on both types are basically the same; be aware that the digital scopes may hide some of there controls in a menu on the LCD display instead of using knob or button.
Remove these ads by
Signing UpStep 1: Controls Overview
- at least one input where an oscilloscope probe (also called a coaxial cable) can be attached (be sure you have one of these cables)
- screen with a grid overlay- this grid is useful when you want to make measurements using the scope
- volts/div- this control lets you change how many volts are represented by each vertical increment of grid overlay on the screen. Basically, it allows you to zoom in and out along the y axis.
- time/div- this control lets you change how much time is represented by each horizontal increment of the grid overlay on the screen. It allows you to zoom in and out along the x axis.
- vertical position/offset- lets you move up and down in the y direction
- horizontal position/offset- move left and right
- trigger level- this is a tool that allows you to stabilize your waveform on the screen, I'll get into the details later on in this tutorial
See the images above for examples.
Visit Our Store »
Go Pro Today »
http://www.instructables.com/id/DPScope-Build-Your-Own-USBPC-Based-Oscilloscope/
and it works fine ..
attaches to pc via USB .. it's software runs fine, too, on this XP Pro lappie ... I'd recommend it to anyone who can handle a small solderiron..
These cheap ones are pretty limited in their frequency range.
http://www.virtualvillage.com/pc-based-oscilloscope-2-channel-digital-storage-001482-009.html?utm_source=googlebase&utm_medium=shcomp&utm_campaign=google_shopping_feed
I haven't used one myself yet but know of others who have used such a device for amateur projects.
