Otter Will Crush Your Soul Cross Stitch +pattern
7,259
187
13
Posted
Introduction: Otter Will Crush Your Soul Cross Stitch +pattern
I came across this picture while browsing the internet and liked the sentence. Nevertheless I wanted to make a full otter and I wanted the threat to be less about physical violence and more about moral violence, because otters are so cute and creepy (yes they are). Looking for otter patterns I didn't quite find what I wanted so I settled on altering this one. I found the alphabet here, it is supposed to be the Twilight font (I'm not a fan but the font is nice).
I have already done a cross stitch tutorial in the past so I'm just going to repeat what I said about cross stitching.
Those of you who are familiar with cross stitching can go directly to step 3.
Step 1: Tools and Materials
You will need :
- Embroidery floss (the colours on the photo are wrong) : brown, light brown, ivory, blue, light blue, black. I used some leftovers I had from previous projects so I don't know what their reference numbers were.
- Aida cloth or other fabric fit for cross stitch. The size of the image in the end will depend on your type of cloth and how far apart the holes in it are.
- An embroidery hoop and a small screwdriver will be very helpful but you may do it without hoop (if you use a hoop though, you will need a screwdriver). I prefer wooden ones to elastic plastic ones.
- Scissors and a needle (embroidery needles are usually bigger and less sharp than sewing needles, and their eye is bigger).
- A frame. I advise you to wait until you have finished stitching before buying it.
Step 2: How to Cross Stitch
Cross stitch is made of little crosses side by side which make a big picture (a bit like pixel art).
The hoop is used to stetch the fabric and make it easier to stitch on it. Take the two circles apart. Put the smaller one on a table and place you fabric over it. Use the screwdriver on the bigger circle to widen it. Put the bigger circle on the smaller circle and trap the fabric between the two. Ajust the fabric before tightening the bigger circle.
Your embroidery floss is made of 6 threads. Cut a length of floss. Take two threads out of six and pull them through the eye of your needle. You don't make knots before cross stitching as you do when you sew.
Take a scrap of fabric and practice as follows before actually starting your project.
Pull your thread through a hole in the fabric, from under (the wrong side) to the top (the right side). Your needle must not catch the threads of the fabric. Pull the floss out, but not entirely, and leave a little length under the fabric.
Try to visualize the little squares in the fabric. You are at the bottom left corner of one square, now put your needle across it in the top right corner and pull through (then again, not entirely). You should have made a diagonal half-cross. Put the needle (now it should be under the fabric) through the hole that is just under your last one. As you do this, the floss will make a small loop under the fabric. Trap the loose end of your floss in it. On the right side of your fabric, you are now at the bottom right corner of your square. Put the needle across it into the top left hole. It should make a tiny cross.
When you have large areas to cross stitch, make all the half-crosses before going back and finishing them. It allows you to save floss and to make it look neat. All your crosses should be in the same direction (from bottom left to top right, and then from bottom right to top left, or the opposite, but stay coherent).
You can find several videos on Youtube on how to cross stitch if you think I am not clear enough.
To stop your thread and use another one, finish the half-cross you are doing, then go on the wrong side of the fabric. Stick your needle under a strand of floss, and then under the small loop you just created. Tighten and cut the floss.
Step 3: Stitching the Pattern
Here is the pattern that I made, you can print it or follow it from your screen. To keep track of what you are doing, I suggest you print it, start stitching and colour what you have done every 5 crosses or so with a pencil.
Fold your fabric in 4 to find the centre of your fabric and start stitching fom the middle, it will prevent you from arriving to the edge and running out of fabric. The middle of the pattern is shown by the black lines.
The black stripes on the clam are not cross stitches. Once you have stitched the gray crosses, make three longer straight stitches with black floss (see what straight stitches are in Jessyratfink's tutorial on embroidery).
Step 4: Frame
Measure your embroidery, take margins into account. A bright colour frame may draw attention from your embroidery. I used a 24 cm x 30 cm black wooden frame.
Follow this nice instructable on how to frame a cross stitch.
That's it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
13 Comments
Are they clams that they crush? and then eat? i thought it was sea urchins. idk i guess you learn something new every day.
great instructable. it is a hilarious quote. i love it.
I've always been told they used rocks to open clams. Maybe they also eat sea orchins. I am only positive about seashells (you can find videos of otters banging rocks on seashells placed on their stomachs).
Thanks. I modified the quote, apparently it was from southpark.
I loooooooove this so much. I must do this!!!
