3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Outdoor 3-Way Speaker Sound System 12V
Step 9The 12V battery
The 12V battery
The battery that I use is 105Ah. With the use of Ohm's law you can calculate the time the battery should run on your system.
When using such a amount of power from a 12V battery make sure you use thick power cables, else your system simply doesn't get enough power to reach his maximum.
1 comment
Jun 19, 2008. 6:58 AMHandsome-Ryan says:
How are you using Ohms law to calculate run time? There are so many factors affecting run time including amplifier gain settings, ambient temperature, the non-linear discharge rate of the battery, and even the volume and type of music being played.
Sep 20, 2008. 12:49 PMalex-sharetskiy says:
get an amp meter, play music for a muinute, check how many amps are drawn, then TRY to calculate
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:themakeclass
