Outdoor Bar Table Top
10,665
160
4
Published
Introduction: Outdoor Bar Table Top
Today I'm going to show you the steps to make a metal bar top with recessed ceramic tile.
All of this was made at TechShop!  www.techshop.ws
Equipment:
Horizontal Band Saw (Would've used Cold Saw, but it was under repair)
MIG Welder
Clamps
Rags
Degreaser
Sharpie Marker (Silver)
Square
Material:
12 foot, 1" by 2" Rectangular Steel Tubing
18 gauge Steel
Ceramic Tile
Black Glossy Spray Paint
Black Silicone
Step 1: Cutting the Frame
First, I took the 12 foot bar and set it up on the horizontal band saw to cut my steel frame pieces (Total of 6 pieces).
I set the band saw to a 45% angle and clipped the beginning of the tubing.
From there, I flipped the bar (to reverse the angle). I measured 68" from the furthest edge and cut it.
I repeated this one more time to make the 2 wide pieces of the perimeter frame.
I then made 2-28" bars with 45% angles to finish off the outside perimeter rectangle of the frame.
From there, I got creative and decided that I wanted to put cross beams in the middle to split up the tile surface that I was planning on putting down.
The 2 cross pieces I cut were flat ended 24" bars to fall in the inner dimensions of the 28" sides.
Step 2: Lining Up and Welding Frame
Once all the bars were cut, I cleaned up the oily steel tubing with some degreaser and then took them to the welding table.
Each bar I squared off, clamped down, and then tacked my welds
From there (after I re-checked each square), I finalized the welds.
Step 3: Welding in Steel 18 Gauge Sheets
Once the perimeter of the bar was made (with the 2 cross beams installed as well), I cut down 18 gauge flat steel with the sheers to sit in the openings.
Now I originally was going to keep the steel sheeting level to the top of the steel tubing for a flat top. However, I had a brilliant idea. Ceramic Tile! How can I include ceramic tile?!
Well, what I did was set the tile pieces that I came up with in the openings of the steel tubing perimeter. From there, I set my steel sheeting over top of that ceramic. (Accounting for the exact recessed distance needed).
I then tacked the sheets, confirmed that the steel was sitting flush, (which I had to break a tack or 2 to bend and hammer it to level). I finished off the welds soon after.
Step 4: Finishing the Steel
Once everything was welded in place, I took an angle grinder and cleaned up all of the welds.
I then hit the steel with a few coats of Gloss Black Spray Paint.
Step 5: Setting the Tile in Place to Finish
After painting the steel frame for the bar top, I then set my selected tile in the openings.
Once I lined up the tile with an even spacing between each, I filled in the gaps with black silicone. (I also siliconed the ceramic tile underneath so it wouldn't pop out).
Thanks for looking at my project!
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    4 Discussions
    Now that looks like a great way to keep the sun off yer back while yer mixin' up fine cocktails....YESSSSS!
