For just a few dollars more up front, these outdoor lighting cans can save you a bunch of cash in the long run.
Remove these ads by
Signing UpStep 1What You Will Need
BILL OF MATERIALS:
5" x 4" Heating / Ventilation Taper Reducer
Lighting Gels (color as desired & high heat rated)
5" Screw Drive Hose Clamp
High Heat, Flat Green (or Flat Black) Spray Paint, RUST-OLEUM brand
100 watt Clear Flood Light Bulb
Outdoor Flood Light Base Assembly
TOOLS:
Tin Snips
Standard Screwdriver
Safety Razor Blade (not shown)
http://www.instructables.com/id/Poor-Mans-Landscape-PAR-Can/
Thanks for the inspiration!
Steve
Thanks!
Steve
I am using them For DJ lighting.
I used a 60w 240v bulb. My housing is made from golden syrup tins (becuase they are reflective and insuferable to heat)
This is covererd by a cardboard tube which I am going to paint
Picture below
We did a little something at our house and it came out really good
For those who really want the labels removed, WD40 works wonders, just spray it on, let sit a couple of minutes and off it comes
Thanks!, for the WD40 tip. I'll use it next time. Anyone who uses WD40, do clean all traces of it off your reducers and clamps so the paint will stick. Thanks for the feed-back.
