Outdoor Pull-Up Bar
 by frenzy
Featured
This instructable will show you how to make an easy and cheap pull-up bar you can mount outside. Pull ups are one of the best exercises and hardest to do. Once you can do them, your body strength will be pretty good.
Step 1: Materials List
The materials list is pretty small, and is pretty flexible, but here is what i used
1 long galvanized pipe
2 shorter pipes
2 elbow pieces
2 mounting rounds
8 wood screws
Tools that will make it easier:
Power Drill
Monkey Wrench (optional)
roz19szcze12bioca says: Sep 5, 2012. 3:01 AM
Sprawdzanie zawartości
Ogólnie znana teza głosi, iż użytkownika może rozpraszać zrozumiała zawartość strony, kiedy ten chce zobaczyć sam jej wygląd. Jedną z mocnych stron używania Lorem Ipsum jest to, że ma wiele różnych „kombinacji” zdań, słów i akapitów, w przeciwieństwie do zwykłego: „tekst, tekst, tekst”, sprawiającego, że wygląda to „zbyt czytelnie” po polsku.
splazem says: Jun 27, 2011. 4:43 PM
Awesome! I gotta make one of these.
Jayefuu says: Apr 18, 2010. 12:17 PM
When you get too badass for two arm pull ups, tie a piece of rope to it to help you working towards the almighty one-armer. :D
snowluck2345 in reply to JayefuuJun 22, 2011. 6:37 PM
or just do increased weight ultil you can do one armers.
xenor in reply to JayefuuApr 20, 2010. 9:07 PM
A similar technique is to just hang a small towel over the bar and use the same way as a rope.
ah-el says: Apr 23, 2010. 5:43 AM
tanks you
DainiusGB says: Apr 19, 2010. 8:22 AM
 I know a guy who made a surprisingly strong pull up bar in a doorway from a sturdy piece of driftwood, some wire, and 2 screws.
frenzy (author) in reply to DainiusGBApr 20, 2010. 8:05 PM
Post some pictures if you have them!
jdtwelve12 says: Apr 20, 2010. 10:49 AM
Nice work!
I believe those are chin-ups you're demonstrating.  For pull-ups, the palms of your hands face the other way.  See: http://stronglifts.com/how-to-do-pull-ups-and-chin-ups-with-proper-technique/ for a better explanation of the difference.
One thing I've always noticed with chin-ups is that the body has a tendency to swing under the bar.  (Cheating, or bad form, yes I know.)  Your placement of the bar close to the wall would seem to help encourage good form.  Do your elbows ever bump the wall?
JacobAziza says: Apr 18, 2010. 11:07 AM
My walls aren't strong enough, so I took two long pipes that go down from the ends of the grip (instead of toward the wall) and rests on the floor.
Its not as stable as a permanent mount, but it means I don't have to put any holes in the wall.
I find it is much more comfortable if you wrap an old inner tube around the bar (or wear gloves)
solo.card says: Apr 18, 2010. 10:31 AM
I like it! I have a bar in the garage for a similar purpose...
Just wondered; how do you find doing pull ups so close to a wall?
frenzy (author) in reply to solo.cardApr 18, 2010. 11:06 AM
its pretty ok, the pipes keep it away from the wall enough for sure.
tom-mot says: Apr 18, 2010. 8:45 AM
 Its pretty cool showing your mates at school 1 handed pull ups :D
SexySexySexyAntonio says: Apr 17, 2010. 10:49 PM
this is nice and useful
lemonie says: Apr 17, 2010. 1:39 PM
Nice bit of purposeful DIY.
L
milsorgen says: Apr 17, 2010. 11:54 AM
 I'd make sure to add some cheap general purpose sealant around the pieces you are screwing to the wall to prevent any moisture issues and what not.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
