3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Outdoor Pull-Up Bar
Outdoor Pull-Up Bar
This instructable will show you how to make an easy and cheap pull-up bar you can mount outside. Pull ups are one of the best exercises and hardest to do. Once you can do them, your body strength will be pretty good.
Step 1Materials List
Materials List
The materials list is pretty small, and is pretty flexible, but here is what i used
1 long galvanized pipe
2 shorter pipes
2 elbow pieces
2 mounting rounds
8 wood screws
Tools that will make it easier:
Power Drill
Monkey Wrench (optional)
15 comments
Jun 27, 2011. 4:43 PMsplazem says:
Awesome! I gotta make one of these.
Apr 18, 2010. 12:17 PMJayefuu says:
When you get too badass for two arm pull ups, tie a piece of rope to it to help you working towards the almighty one-armer. :D
Jun 22, 2011. 6:37 PMsnowluck2345 says:
or just do increased weight ultil you can do one armers.
Apr 20, 2010. 9:07 PMxenor says:
A similar technique is to just hang a small towel over the bar and use the same way as a rope.
Apr 23, 2010. 5:43 AMah-el says:
tanks you
Apr 19, 2010. 8:22 AMDainiusGB says:
 I know a guy who made a surprisingly strong pull up bar in a doorway from a sturdy piece of driftwood, some wire, and 2 screws.
Apr 20, 2010. 10:49 AMjdtwelve12 says:
Nice work!
I believe those are chin-ups you're demonstrating.  For pull-ups, the palms of your hands face the other way.  See: http://stronglifts.com/how-to-do-pull-ups-and-chin-ups-with-proper-technique/ for a better explanation of the difference.
One thing I've always noticed with chin-ups is that the body has a tendency to swing under the bar.  (Cheating, or bad form, yes I know.)  Your placement of the bar close to the wall would seem to help encourage good form.  Do your elbows ever bump the wall?
Apr 18, 2010. 11:07 AMJacobAziza says:
My walls aren't strong enough, so I took two long pipes that go down from the ends of the grip (instead of toward the wall) and rests on the floor.
Its not as stable as a permanent mount, but it means I don't have to put any holes in the wall.
I find it is much more comfortable if you wrap an old inner tube around the bar (or wear gloves)
Apr 18, 2010. 10:31 AMsolo.card says:
I like it! I have a bar in the garage for a similar purpose...
Just wondered; how do you find doing pull ups so close to a wall?
Apr 18, 2010. 8:45 AMtom-mot says:
 Its pretty cool showing your mates at school 1 handed pull ups :D
Apr 17, 2010. 10:49 PMSexySexySexyAntonio says:
this is nice and useful
Apr 17, 2010. 1:39 PMlemonie says:
Nice bit of purposeful DIY.
L
Apr 17, 2010. 11:54 AMmilsorgen says:
 I'd make sure to add some cheap general purpose sealant around the pieces you are screwing to the wall to prevent any moisture issues and what not.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
399
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
