Introduction: Outlets of the Future Aka In-wall USB Charger
Your Iphone is dead, someone has run off with your Ipod wall charger, if only it where the future and all outlets were USB!
This instructable will show you how to convert a standard outlet into an inwall USB Charger. In about 30 minutes and for under $10.00.
Not only will this add a permanent place to charge your USB devices. It will get your home ready for the future, when most appliances are USB. (I make no guarantees this will happen)
Step 1: Materials / Tools
Materials
2 - Mini USB chargers ($3.00 - $9.00 on eBay)
1 - Blank wall plate (screws included)
1 - Existing wall Duplex.
Epoxy or other strong Glue
Tools
Flat Screw Driver
Exacto or utility knife
Drill or Dremel
Pencil or other making device.
Step 2: Create a Templete
1. Plug the Mini USB chargers into the outlets. Because the USB ports are off center I decided to put them both toward the center. I think it looked better than having them the same direction or both on the outside.
2. Create a Template by placing tape over both chargers as shown in the photo, then cut the tae around the outer edge and don't forget to cut out the USB ports.
3. Mark the outline of the USB chargers on the front (outside) of the Face plate, so you know where the template should go.
4. Pull the Template off of the Chargers and apply it on to the Face plate. using the outline on step 3 to proper place the template.
5. Mark the Face to show where the USB ports need to be cut.
6. Cut the Metal Tabs off of the outlet so it will fit into the electrical box. The Face plate will hold every thing into place. Sorry for got to take a picture.
Step 3: Cut the Holes in the Wall Plate
I prefer to use a Dremel tool, but I've cut many holes with just an Exacto knife.
Step 4: Glue the Mini Chargers to the Wall Plate
Step 5: Connect the Power and Attach to the Wall
DO NOT work with live wires, and do this at your own risk.
There is too much liability to explain how to wire an outlet, do this project without disconnecting the outlet from the wires, keep track of how it's wired when you take the wires off, or have someone who knows how to do it, do this part for you.
once the power is connected, use the screws that came with the face plate to attach the charger to the electrical box in the wall.
Step 6: All Done!
Project Complete: Now you will never have to look for a charger again, or have to leave a computer on all night just to charge an iPod. Besides that once most appliances go to USB you'll be ready to go.
Side Note:
A: If you have the means to solder, there is no need to have the outlet behind the wall plate, you could just soldier the wires to the chargers, this is how I was going to do it, but this was so easy I couldn't see spending the extra time to soldier it.
B: You could also keep one of the outlets, and add only one USB port.
Step 7: 2 Month Update
Comment 1. This Project isn't Green and wastes a lot of electricity.
I was concerned about this, so i picked up a Kill-a-Watt and did some testing. from what I understand the kill-a-watt can't measure under 1A, so there is a margin of error. Even after 24 hours on the kill-a-watt. it registered 0! so I guess I'm ok with amount of energy loss, especially considering my printer, DV player and other electronics I barely use draw .01 per hour and more.
Comment 2. The heat from these units are going to cause your house to burn down.
Again this did concern me, and for the first few weeks, every time I walked by this outlet I felt it for any sign of warmth. I found that even with 2 ipods charging, there was no noticible amount of heat from the transformers. However I did notice that the dimmer switch I have in close proximity gets warm, but not enough to cause damage. conclusion: not worried.
NOTE: I did hear about a recall for the apple micro USB charger, they were shorting out and melting. make sure you have a green dot on the power side!
Comment 3. This is a code violation and when your house house burns to the ground, you insurance will not cover it.
Yes this is a code violation, and I'm open to input about how to make it legit. I'm not running wires down to an outlet, I'm only interested in outlet side fixes.
Conclusion:
This was well worth the $10.00 and 10 minutes of my time to make this. It's been nice to have a designated Ipod charging spot. my whole family has ipods and we all use it. now that the neighbor kids know it's there, they bring over their ipods and charge them while they are visiting.
