Step 2Create a templete
1. Plug the Mini USB chargers into the outlets. Because the USB ports are off center I decided to put them both toward the center. I think it looked better than having them the same direction or both on the outside.
2. Create a Template by placing tape over both chargers as shown in the photo, then cut the tae around the outer edge and don't forget to cut out the USB ports.
3. Mark the outline of the USB chargers on the front (outside) of the Face plate, so you know where the template should go.
4. Pull the Template off of the Chargers and apply it on to the Face plate. using the outline on step 3 to proper place the template.
5. Mark the Face to show where the USB ports need to be cut.
6. Cut the Metal Tabs off of the outlet so it will fit into the electrical box. The Face plate will hold every thing into place. Sorry for got to take a picture.
Cooked food, (especially meat) is why we are tinkerers not tree dwellers :-)
2) If you could, it would kill whatever device you are using because the standard wall socket has WAY to much electricity to charge anything with.
