Step 6All done!
Project Complete: Now you will never have to look for a charger again, or have to leave a computer on all night just to charge an iPod. Besides that once most appliances go to USB you'll be ready to go.
Side Note:
A: If you have the means to soldier, there is no need to have the outlet behind the wall palte, you could just soldier the wires to the chargers, this is how I was going to do it, but this was so easy I couldn't see spending the extra time to soldier it.
B: You could also keep one of the outlets, and add only one USB port.
http://www.engadget.com/2009/12/05/10-usb-power-outlet-leaves-no-plug-behind/
Much safer and not all that more expensive (a couple bucks maybe).
What would be extra cool would be to have a mini-usb jack, and then you could double or triple them up on the one socket plate.Great job.
Second, I don't see how this will fit inside a standard wall box. Wouldn't you have to cut the mounting ears off of the outlet to make it push back into the box far enough to make the face plate flush out with the wall? Even if the box is deep enough, I'm not sure that it's a good idea to have it all suspended from the plate by glue and the friction of the charges in the sockets.
This is a neat idea, but I don't think that burning down one's house is the solution to getting rid of your wall warts.
Are you australian or something? (they aren't even allowed to put a plug on a wire, has to be done by people with a permit if you can believe it)
As long as the connection is mechanically sound you can solder it and
insulate with tape.
"Twist-and-solder wire conductors
Q: Does the NEC permit twisting all of the equipment-grounding conductors together and soldering them in a junction box? Can solder be used to splice branch circuit conductors?
A: Twisting conductors together for splices and taps and then soldering them is still an acceptable method of making connections. In 110.14(B) this sentence appears: “Soldered splices shall first be spliced or joined so as to be mechanically and electrically secure without solder and then be soldered.” Tightly twisting the conductors together makes them mechanically and electrically secure and prepares them for solder. Solder flux used on the splice cannot adversely affect the conductors or equipment.
Because equipment-grounding conductors are being connected together, it is appropriate to look at connection methods permitted in Article 250-Grounding and Bonding. There is a sentence in 250.8 that limits the use of solder, but it does not apply to this question. The sentence that restricts the use of solder reads: “Connection devices or fittings that depend solely on solder shall not be used"http://www.ecmag.com/?fa=article&articleID=6268
Also, while its true that you really shouldn't do this / solder unless you really know what you're doing, tin/lead solder is used all the time in the appliance industry, and will not cause any problems.
That being said, you should not be trying to solder something like 12 guage standard solid copper wire to anything. If you are, stop now, and get someone who knows what they're doing.
But yeah don't do that with stuff where you actually put power on them, and even with stranded wire make sure you use a heavy soldering iron and not some 15 watt model,
And don't trust electrical tape will stay on it for extended time, better to use something else like heatshrink or better yet, if there is any possibility, or the wire is not fixed, you use the common wire connectors for mains and not soldering.
And dryers, also AC, both clothes dryers and hairdryers.
And regular lightbulbs also use AC, and blenders also, so you see there are many things in the home that work on AC.
My time is usually long dead and cannot be revived.
If that's the case, why not just forget about the whole instructable and leave the outlet the same and use the USB adapter on the outside like it was intended to be used? That way it doesn't have to be a dedicated USB outlet all the time.
Personally, I would be scared to have some Made in China USB adapter permanently glued inside my wall.
A better route would be to run dedicated low voltage wires to each desired wall plate and use keystone connectors like these:
http://homeavcables.com/usb-a-wh.html
They could all be wired to a single 5V DC transformer located near the panel. The new USB3.0 will allow up to 900mA power which will help a bit too. http://en.wikipedia.org/wiki/Universal_Serial_Bus#USB_3.0
Or you could put the USB adapter outside the wall plate (duh)!
I really don't see an advantage for all of this. You lose a mobile charger and a precious outlet. But, I guess if you were to do it, then just crimp the lines rather than solder.
