Nearly every time I ask my boyfriend what he wants for dinner he says ribs, fried chicken, or barbeque. Even when we don't have any meat at all in the house. It's also important to note that we do not own a grill! He's determined.
Last time we went grocery shopping, he really wanted to buy ribs, so I made up my mind to learn to cook them in the oven. I originally wanted to go the "sauce-the-hell-outta-them" route because I had read that was easier for beginners, but Tyler was jonesing for a dry rub. So I had to figure that out as well.
Needless to say, they turned out well and I can't wait to make them again!
Remove these ads by
Signing UpStep 1: What you'll need:
- a rack of ribs (I used the "baby back" variety)
- a baking sheet
- cooling racks or other wire racks to keep the meat above the baking sheet
- spices for dry rub (recipe on next step!)
- an oven set to 300 F
Visit Our Store »
Go Pro Today »
A couple pro tips would be to remove the silver skin membrane on the bone side of the ribs before applying the rub...use the Google for instructions. This membrane inhibits flavor penetration and gets caught in your teeth as well as being hard to digest.
There is a lot of debate in the BBQ world about dry vs wet smoking...basically whether or not you introduce steam and how much into the equation. While you're not smoking (BBQing) here I think the moisture question is still in play. I'm a proponent of moisture...if you have a gas oven you're getting some moisture from the combustion if you are electric you aren't. In any case you might consider adding a water tray for steam. As always experimentation will determine the right setup for you. I personally add water to the drip pan in my smoker to add moisture and prevent drip fires.
You might also consider an extended resting period (1 hour) wrapped in foil + a towel and or in an empty cooler (no ice) this will further break down the collagen in the rack and produce that fall off the bone texture that is the goal of traditional BBQ.
"You don’t win friends with salad.” — Homer Simpson
I do thankfully have a gas oven! And I think I will try your suggestion to add a little water to the pan next time... anything to make them even better!
The resting wrapped in foil is a good idea, too. Thank you so much for all your tips. You've really helped a noob out. :D
I keep wanting to try the liquid smoke, I bet it's amazing!
You mentioned that you might drop the temp to 275 F.
Try this, it works great for me.
Spice up the ribs with your rub.
400 F for 20 minutes then 250 F
When you turn the oven down after the 20 minutes you can apply a little sauce.
then monitor every 45 minutes.
This also works great for beef short ribs. :-)
thanks for sharing
This is definitely how we will do our racks of ribs in the future. Thank you jessy!
I'm off to smoosh together a dry rub and to rub those ribs. Then it's back to the fridge for a long nap while I snooze. Once we've both had our beauty sleep, the ribs are headed to the oven for a long, slow bake, as you suggest.
I'll report back and let you know how it all turns out. Thanks again.
Thanks for the RUB recipe. I've always bought my rub from the store since
I didn't know what all was in it and/or how much :-)
Another GREAT recipe for ribs is:
Delicious BBQ: Fall Off the Bone Beef Ribs
Will
Kudos on the success!
