Introduction: Over Cabinet Lighting Using LED Modules or LED Strip Lights
About: We carry high quality LED Lighting products and provide the highest level of customer service. Let our knowledgeable and friendly staff help you with your next LED lighting project.
If you have unlit space above your cabinets you might be surprised by the amazing lighting ambiance you can create using LED Modules or LED Strip Lights. Above cabinet lighting is much simpler than under cabinet lighting due to the fact that the LED Modules or Strip Lights are not visible and the installation doesn't have to be concealed like under cabinet lighting. If you want to see how to install over cabinet LED lighting view the second half of this project from http://www.ecolocityled.com to see how great your home or business can look with both under and above cabinet LED Lighting.
LED Products Used from Ecolocity LED:
Super Nova 4 LED Modules - Warm White
40W 12VDC LED Power Supply
22AWG DC Connection Wire
2 Prong Power Cord
Step 1: Measure and Clean the Mounting Surface
The first step in your above cabinet lighting project is to measure the space that you would like to illuminate. You want to measure not only the length that you want to illuminate but also the upward distance that you would like to light, this will help our sales team at EcolocityLED.com better assist you in receiving the best possible LED lighting solution for your project.
After you have purchased your LED Modules or LED Strip Lights from EcolocityLED.com you can now begin your lighting installation. First off you want to clean your mounting surface so the double sided VHB tape will adhere for the lifetime of the product. Use rubbing alcohol to clean your surface and allow plenty of time to dry. If you do not have a clean smooth surface to mount to you can always mount the modules using screws or the strip lights using mounting clips or Aluminum Extrusions.
Step 2: Mount Your LED Module or LED Strip Lights
Now that you have cleaned your mounting surface you can simply peel off the cover of the VHB double sided tape and stick your LED Modules or LED Strip Lights to your mounting surface. Be sure to press firmly to be certain the tape is sticking to the surface.
Step 3: Install 12VDC LED Power Supply
Now that you have your LED Modules or LED Strip Lights installed you can now install your Low Voltage LED Transformer / Power Supply. Most all LED Modules or LED Strip Lights power by low DC Voltage, in this case we are using a 12VDC Power Supply with 120VAC input. If you do not have any experience working with high voltage electricity hire an electrician to install your power supply, never install a power supply when input ac power is live. Hook your 120VAC input to your power supply and 12VDC output to your LED Modules or LED Strip Lights. Never leave bare wire connections, always use wire connectors or solder and heat shrink.
Step 4: Turn on Power and Test Your Connection
Once your LED Transformer is properly installed you can now apply power to the unit and test your LED Lights. If your lights come on you know you have done everything properly, if your lights do not come on you have a bad connection or have the polarity of your wires wrong. If you need assistance troubleshooting an LED connection view our Voltage Multimeter Troubleshooting Guide or hire a professional to install.
Step 5:
Once your LED Lights are working you can clean up your work space and add appealing accessories to your newly lit above cabinet space. As you can see the final result adds a new whole new perspective to this kitchen that will last a lifetime.
