Arduino Relay Control Over the Internet
7,825
48
10
Posted in TechnologyArduino
Introduction: Arduino Relay Control Over the Internet
Welcome!
Step 1: Make a Sketch
Use the sketch to connect the relay to the Arduino.
The sketch will help you when you will be writing the code, so that you will know what pins you need to control with the code.
I'm using an Arduino with the W5100 Ethernet Shield Network Expansion Board, to connect to my home network
Parts:
Arduino Uno
http://www.amazon.de/gp/product/B008GRTSV6?keyword...
4 channel relay board
http://www.amazon.de/SunFounder-Module-Kan%C3%A4le...
http://www.amazon.de/Aukru-Ethernet-Micro-SD-Karte...
Jumper wires MALE - FEMALE
http://www.amazon.de/Aukru-jumper-wire-Steckbr%C3%...
Step 2: Wiring
Cut open the wire for the lamp or other electronics you want to control. Cut one of the two wires and stripe it on both sides and connect the wires to the relay¸
If you connect the wires to the two inputs on the relay that are showing a connection, you won't be able to control the relay
Step 3: Code
You can change your IP address by changing the last number on the IP address
(byte ip [ ] = { 192, 168, 1, 30};)
Step 4: Test
When you are finished .
You just open a web browser and type the IP address that you used in your code.
I should look something like that site in the picture.
And that is it!
Thanks for reading my inscrutable!!! :):)
Step 5: Other Projects
Here are some links:
My site:
https://tjasdeveloper.wordpress.com
YouTube :
https://www.youtube.com/channel/UCE7-9VZ2heI1D8yk2...
I will be doing some other projects with the RPi 2, when a will have more time!!
English isn't my first language, so please excuse any mistakes.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    webpage is not opening..Please help me
    10 Comments
    Hi, i try it now at home, but only 1 relay work, on/off at any numbers. So if i push off the button 5 rellay 1 go off, if i push button 8 go online only number 1. Any idea?
    also only first led works
    are u sure control over the internet?why i just can using lan to control?
    Could be this done with a wifi shield instead of an ethernet shield?
    Thanks so much. But when i connnect arduino with power ( with out usb computer ) i can't entry web address. Can you help me.
    I use the USB port to power the Arduino, I have no way to test the power port, because I don't have the power supply
    Hi,
    I’m irinakim and I’m work in the Wiznet.
    Thank you for using our product.
    We are collecting so much data using ourproduct.
    And I will post the this project on our Web site.( http://wiznetmuseum.com)
    Can I post your product on our Web site?
    yes you can, thanks for the comment
