Thinking for quite a while about a sturdy and cool bike light, I found a great motorcycle head light at a 2nd hand market.
My initial requirements for the lights: (After installing the fixture, the worsest engineering problem occurred: intermittent failure. It required lots of changes, which are added in ITALICS). This is a real life example of KISS (keep it simple, stupid)
- Bright, preferably illuminated with LEDs.
- Running on === 6 V, since my bike has a hub dynamo.
- Good functionality, but possibility to switch to additional subtle and less subtle effects.
- Reasonably theft and vandal proof
My requirements for the handle bars:
- Light has to fit in between the vertical parts.
- Ergonomic design
Materials for the light:
- 'camping light'
- dynamo: hub type.
- Motorcycle head light from 2nd hand market.
- wiring, switches and circuitry to switch on and transform to 4.6 and 2.5 V
- nuts & bolts, glue, etc.
- paint
Materials for the handle bars:
- 22mm galvanized pipe
- 2 Tees, .
Tools: standard tools, a pipe bender and torch with soldering stuff. Pipe benders usually can be rented. Soldering tools for the circuit.
Remove these ads by
Signing UpStep 1The handle bars
I am 2 m (6'6") tall. A few years ago, I obtained a 2nd hand 7 speed hub (Shimano Nexus) bike. It was a bit too sporty for me: I need a strong bike, with lots of transport capabilities, able to carry a good load, and tow a trailer... Tall people need to modify everything, and one of the things to be changed were the handle bars.
The first mod was to attach some handlebar extensions. The low position makes my hands numb and my neck stiff, as I have to point my head up all the time.
This stuff is normally used to enable bending over even more than the pitifully low standard position of handlebars allows (as many folks are craving to get an even better view of the asphalt being traversed), but in my case, they were quite helpful in allowing a more upright position.
It is nice stuff... sandblasted aluminum, with a good feel... in summer..., pipe insulation is needed in winter....
Finally, my handlebars broke in two (forgot to reattach the bracket of the front brake :o ).
The new handle bar design is much higher, so new, longer cables had to be bought to fit.
Central heating (thin steel pipe, 22 mm, or conduit...) galvanized pipe was used. Nothing was bought, as most large home renovations involve discarding loads of perfectly good pipe... (anyway, pipe is not expensive).
Tee joints were used for the corners. Why not elbows? On both sides, a yellow LED shines trough...
It can be used as is, but brass- zinc used together invites corrosion. A (black) paint finish slows this down, and looks cool. Yearly touch-ups are probably a good idea.
The light fixture needs to fit smugly between the vertical elements of the handle bars. It is fixed by 2 M8 bolts.
The transport carrier is made out of a handcart: www.instructables.com/id/Bicycle_Front_Transport_Carrier/
I just got a Falcon beach cruiser bike, I want to go with a motor bike lamp with maybe a 3w LED bulb
The "transport carrier" is cool.
I also find your handlebars most interesting.
What method did you use to secure the Tee to pipe?
For my trailer I used compression fittings: it allows quick replacement of the hitch (version 1 and 2). The long and high one can also be used for pulling the trailer by hand.
