While I built mine to hold my whiteboard, it could be used for painting, drawing, or any other easely purposes.
Remove these ads by
Signing UpStep 1Supplies
- Ply wood - I got a $2 board from the cull cart at Home Depot.
- 4 "U" brackets - These are in the same section as the lumber. Mine cost $0.76 each
- 2 hurricane straps, they're basically strips of metal with holes in them. Same section as the U brackets. Mine are 2ft long. Mine cost $1.15 each
- 14 screws shorter than your wood is thick
- Hot glue/wood glue
- Felt pads
- Circular Saw
- Sandpaper or Sander
- Screwdriver
- Drill
- Carpenter's square (I used a free sample of carpet)
- Tape measure
- Vise
. Plumber's strap is made from soft steel and is very easy to bend - it's made to be bent by hand (no Bender robot required heehee). If much weight were put on his hanger made from plumber's strap, it might "unbend."
. Plumber's strap might work for this project (it would certainly be easier to form), but I think W'burg came up with a better solution. His straps are probably 10x stronger than they need to be, but there may not be many easy options between his straps and plumber's strap.
