Over-the-bed Computer Cart
Does your laptop overheat? Neck cramps from those poorly made computer carts from staples? This is a simple to make cart that will make you and you computer happy at the same time.
Step 1Materials
Materials
1x12x8 pine board
4 wheels
2-inch pipe the height you desire (aprox 2-3ft)
2 pipe cuffs and 2 threaded joint joiner
nuts, bolts and screws
epoxy putty
1-2 concrete patio blocks (for weight)
Drill, Sander, Wood Glue, Saw, Paint
14 comments
Mar 28, 2010. 12:06 PMsdallesasse says:
This would also be good as a sofa  TV snack table.  Just have to keep the bottom thin enough to fit under the sofa.
Jan 13, 2009. 6:15 PMxd12c says:
I really like the simplicity of this design. Though for asthetic purposes, I would think about either enclosing the patio blocks in the base (maybe a simple box or even a fabric covering to protect the finish?) or using a different material for weighing the base down. However, I am very impressed with it & I will be looking into building one myself
Jan 11, 2008. 8:54 PMtresho says:
A local hospital has a rummage sale / flea market once a year. I picked up an excellent hospital version of this for $5. Washed it off with soap & water, then diluted bleach & having been using it for years. Hospital versions have up & down adjustments & a small drawer below the main platform.
Mar 7, 2007. 10:58 PMledzeppie says:
i h8 my dad. he thinks that this would not be able to support the weight so he wont let me build it....i think hes just to dam lazy to go to rona
Sep 28, 2007. 11:28 PMYerboogieman says:
if you use the right stuff you can do it, just not with plywood and a coat hangar, i think thats what hes thinkin...
Apr 12, 2006. 12:37 AMRobbGodshaw says:
you should run some power, usb and VGA extension cords through the pipe for looks and anti-tangleage, also i think for the pipe, two inch plumbing pipe would probrably be stronger.
Mar 6, 2006. 10:13 PMsmitty says:
what kind of pipe is it? and where did you get it?
Mar 18, 2006. 8:06 PMsimplifiedbuilding says:
You might be able to use some of the fittings and pipe from www.simplifiedbuilding.com
Mar 14, 2006. 5:42 PMyou_bunch_of_losers says:
Do you find it wasy to wipe down??
Mar 10, 2006. 11:49 PMmgbeck says:
Instead of Conduit I would have used 3" pipe. You wouldn't have had to use the conduit connector on the bottom. How stable is the table. Looks like it's kind of leaning over?
Mar 8, 2006. 10:54 AMdeprecated says:
Cool project. A lamp of some kind could also be attached to the board, with the wires running down through the conduit and then out to the wall.
Mar 7, 2006. 8:05 AMbrob says:
looks like scaffolding pole to me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Efemmeral
