3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Overdrive Pedal for Rockband Stratocaster (PS3, Xbox)
Step 3Remove the existing button
Unscrew the board over the PS3 button and move it aside as shown. The little white button where our wire wants to be is just held in by a little hot glue. Pick that glue apart with anything sharp (like a tiny screwdriver). Slide the board out and set it aside. I just left mine in there (as far as I can tell, this button is redundant with the PS3 button).
Remove the little white button and bag it up with the crappy tilt sensor. If you ever decide to RMA this guitar and want to try your luck with the warranty, you can re-assemble it with a little soldering on the old sensor and some hot glue for this button assembly.
2 comments
Jan 9, 2009. 4:13 PMdragon0360 says:
I don't know about the PS3, but on the xbox isn't that little white button for syncing to the console? wouldn't removing it produce a problem if you ever had to sync th guitar again?
Dec 7, 2009. 8:43 AMcreativityUnwashed says:
You're absolutely right.
Feb 15, 2010. 9:15 PMspaztec says:
If i'm not mistaken, just resetting the guitar.. on/off does the job. I have used different guitars with different receivers with different playstations. Never have onced pushed the white button.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mourningzero
