Well... now there is! Here's an instructable on how to build it. Granted, this tripod is more of a unipod.
Step 1: Saw Pieces & Make Template
- Pencil
- Eraser
- Index Card
- Miter Saw / Box
- Sand Paper
- Ruler
- Hardwood (30" x 3/4" x 3/4")
Using the ruler, measure, cut and lightly sand the follow lengths:
- 1 of 1 1/2"
- 3 of 3"
- 2 of 10"
- Trace a 3" piece onto an index card.
- Segment traced rectangle into 4 parts.
- Put crosses from coner to corner of each new rectangle.
- Put a cross between the first and last rectangle.
- Label each cross from left to right (A,B,C,D,E).
- Erase any markings on the pieces.
Step 2: Marking Tool
Materials:
- Drill Press
- Sanding Wheel
- Straight Rigid Metal Rod
- Fine Sandpaper
- Sand the tip of the metal rod with a sanding wheel attached to the drill press.
- Insert the roughly sharpened metal rod into the drill press.
- Sand the tip of the rod to a fine point using rough and then soft sandpaper.
- Insert the marking tool into the drill press.
- Line up the tool point with crosshair on the template.
- Insert a work piece over the template.
- With the drill press spinning, lower it slowly onto the work piece.
- Raise the marking tool when there is charring.
Step 3: Hole for Wood Screw
Materials:
- Drill Press
- Marking Tool
- Drill Bit Assortment
- Template
- Masking Tape
- 1 of Wood Screw
- 2 of 3" Hardwood Pieces
- Tape two 3" segments together on all sides lengthwise using masking tape.
- Position template / marking tool / taped segments over template cross 'A'.
- Mark & drill a hole (ex. 1/16" drill bit) so that it does NOT come out the other side.
- Countersink the hole with a larger drill bit (ex. 13/64" drill bit).
- Screw in an appropriately sized screw.
Step 4: Holes for Machine Screws
Materials:
- Drill Press
- Marking Tool
- Template
- Masking Tape
- 1 of Wood Screw
- 3 of 3" Hardwood Pieces
- Rotate the previous workpiece around the vertical axis 180° so that the wood screw is over 'D'
- Tape another 3" segment onto the newly rotated workpiece.
- Mark a hole over 'A' and 'B' using the marking tool & enlarge with a step-drill to the final drill-bit size (ex. 5/32 drill bit).
- Drill a hole over 'A' such that it goes all the way through.
- Drill a hole over 'B' such that it goes through the two top-most pieces and 1/4 through the bottom-most piece.
Step 5: Top Piece Drilling
Materials:
- Drill Press
- Marking Tool
- Template
- 1 of Wood Screw
Dissassemble the workpiece. Lay it out as pictured. From top-most image to bottom-most:
- Top Piece: wood screw termination, 1/4 way hole, through hole
- Middle Piece: wood screw countersink, through hole, through hole
- Bottom Piece: through hole, through hole
- Using a large step-bit, enlarge the 1/4 way hole of the top piece to accomodate a much larger bit.
- Use a large drill bit to create a cavity for a machine screw & washer (ex. 1/2" drill bit).
- Rotate workpiece about the horizontal axis 90° over 'C', mark & drill (ex. 5/32" drill bit).
Step 6: Clamp Holes
Materials:
- Drill Press
- 10NC24 Tap
- For the bottom piece with 2 holes, use a larger drill bit (ex. 3/16") to enlarge the holes for free movement of machine screws.
- With no power applied, manually rotate a tap into the smaller holes of the top and middle work pieces.
Step 7: Clamp Top
Materials:
- Top Workpiece
- Middle Workpiece
- 4 of #10 Washers
- 2 of 3" #10-24 Machine Screws
- 2 of #10-24 Hex Nuts
- 1 of Wood Screw
- Screwdriver
- Wrench
- Insert a washer onto the 3" screw.
- Insert the screw into the middle hole of the middle workpiece and tighten.
- Insert a washer onto the end coming through the middle workpiece.
- Tighten with a hex nut.
- Cover the middle workpiece / screw cap with the top workpiece.
- Screw in the wood screw.
- Insert a washer onto a 3" screw.
- Insert the screw into the top hole of the top workpiece and out through the middle workpiece and tighten.
- Insert a washer onto the end coming out.
Step 8: Finish Clamp
Materials:
- Rubber Cement
- Felt (Scrapbooking / Thin Type)
- Top Assembly
- Bottom Workpiece
- 2 of #10 Washers
- 2 of #10-24 Wingnuts
- Cut out two felt pads for the clamp.
- Attach felt pads to clamp using a coat of rubber cement applied to wood.
- Attach a wingnut followed by a washer to the outermost screw of the top assembly.
- Slide the bottom workpiece onto the top assembly.
- Attach a washer followed by a wingnut to the centermost screw of the top assembly.
- Attach the clamp onto a spare piece for drying.
Step 9: Camera Attachment
Materials:
- Drill Press
- Marking Tool
- Dremel
- Cutoff Wheel
- Pencil
- Eraser
- 1 1/2" Workpiece
- 1/4"-20 Screw
- 1/4"-20 Plastic Wingnut
- Stand the workpiece such that the square portion faces upward.
- Pencil a crosshair from corner to corner.
- Mark & drill a hole at the center of the crosshair (ex. < 1/4").
- Cut the top off the 1/4" screw.
- Screw in / glue the threaded portion into the newly made hole.
Step 10: Arms & Hinges
Materials:
- Drill Press
- Marking Tool
- Atomizer (Perfume Bottle)
- Solvent (Denatured Alcohol)
- Rosin Powder
- Masking Tape
- 2 of 10" Workpieces
- Camera Attachment
- Clamp Assembly
- Using 'A' mark opposite sides of the 10" workpieces and of the camera attachment.
- Drill and tap one 10" workpiece (ex. 5/32" drill bit).
- Drill the other workpiece (ex. 3/16" drill bit).
- Cover area surrouding the 3/4" x 3/4" square around each hinge hole with masking tape.
- Make a 50/50 mixture (by volume) of rosin powder and solvent.
- Spray mixture onto each hinge with an atomizer.
- Allow time for mixture to dry (30 minutes).
Step 11: Finish!
Materials:
- Camera Attachment
- Clamp Assembly
- 3 of 2" #10-24 Machine Screws
- 6 of #10 Washers
- 3 of #10-24 Wingnuts
- Screwdriver
- Screw in a washer + screw into each end of the tapped 10" workpiece and the side of the clamp.
- Slide the other 10" workpiece onto the screws protruding from the clamp side and first 10" workpiece.
- Slide the camera attachment onto the other end of the tapped 10" workpiece.
- Add a washer + wingnut to each protruding screw.
Visit Our Store »
Go Pro Today »
1. I made this with pieces of 1x3 pine cut down to 1x1.5, which gave me more surface area between the pieces and thus more friction and a higher weight limit without the need for the rosin, or inserted sandpaper, etc.
2. Similarly, I used 1/4-20 bolts and both a hex nut and a wing-nut to help me tighten things better. Using the two nuts together I get a very tight joint that stays tight, as the two nuts together bind on each other and do not loosen over time. Rather than loosening and tightening the joints for repositioning, I just leave them tight with a set amount of friction that holds my camera, but still allows me to reposition things.
3. Instead of cutting a bolt to get threaded rod for the camera mount, there is a special bolt called a hanger-bolt with wood thread on one end and machine thread on the other, this will thread into the wood better and still give you the 1/4-20 you need for the camera (you screw this in using the same double nut binding concept, then you take those nuts off and put on the big wing-nut for tightening up on the camera)
4. Rather than building in the clamping mechanism here I just use a large C-Clamp which seems to work fine for me (or really any other clamp you may have: spring clamp, bar clamp, etc.) I like the clamp design, I just didn't want to do the work and have lots of spare clamps around to use.
5. Also, for added flexibility, I added an insert-nut into the bottom piece of the arm (that clamps to the table), so that I also have a 1/4-20 thread in the base that can accept the threaded mount from a tripod, so this can potentially be mounted to a tripod and add both height and flexibility to a tripod you may already have.
6. Finally, I just want to say that this is a great design, so simple, and yet so useful, and portable too. I've built a couple of these for myself and others. One guy uses it for taking product shots of the stuff he sells on eBay, Rather than buy an expensive tripod he can just clamp this to a table and it serves the same purpose of steadying the camera as he takes pictures of small things in front of a simple backdrop. I use it for copying documents and just taking pictures of things where I don't want to, or can't take my tripod. I can clamp this to just about anything and still take great, clear, steady shots. Thanks for sharing this project and design on Instructables.
this is nice and simple.
I'm thinking about some improvements:
- adding a level bubble to keep horizontal the camera
- using larger pieces for the clamp, this means a better grip on the table
- use 3 of 10" , this can lighten the structure that means you can use more thin wood workpiece
I'm thinking about building such "arm" for my digital camera Cannon A550.
But for other purpose. My idea is to add light source, most probably monochrome LEDs around camera. Light source must provide uniform light intensity over A3 or A4 sheet of paper. Then i could use camera as scanning tool.
I'm a student so often i have some hand written notes, sketches which i want to share with my colleagues. For now i use camera on my smart phone but it's not good enough for small handwritten details. Regular low cost digital camera with optical zoom has much better performance.
When i have images, then it's easy to make pdf file from them. Even OCR.
This could bee very cheap replacement for scanner and it wouldn't occupy much space on my desk. :-)
I'm new here on Instructables. Can i post this idea as some sort of project and make a link to this project, but without actually building it?
However, I can see a trade off. If you use a camera, you can more quickly 'scan' in documents in a more compact format, but the resolution will be a lot lower than what can be had with a scanner.
Here's an example:
Assume an 8.5 x 11 in. Assume you can fit this into a 10 Megapixel image using your camera. This means that your DPI (dots per inch) is the square root of (10 000 000 / (8.5 x 11)), which is 327. Most scanners can easily do 600-1200 DPI.
I should also be noted that if someone is not that handy with wood, or cant get the material, one could get the Tertial IKEA lamp and easily mode it as a stand.
http://www.ikea.com/ca/en/catalog/products/20370383/
I have experience with very similar lamp and it was difficult to make it stand still. So i assumed that this lamp have similar problem. Especial after use of some time because metal becomes smooth and it's difficult to tighten screw on joint enough.
You're right about the weight, Although the 3/4" x 3/4" hardwood is probably strong enough to support several pounds, the weight is actually held by the junction between two pieces of wood and the wingnuts, so it's key to make that rough / sticky as possible to support as much weight as possible.
But... with one leg, wouldn't that be a monopod and not a tripod?
However, functionally, it does what one would expect a camera tripod to do which is to hold a camera in a fixed position away from an object. I figure it made more sense for me to call it a tripod, due to the device's functional nature. If someone desired to build a device for suspending a camera overhead it seemed more likely to me that they'd search for a tripod than a monopod or crane.
I think the more usual thing to search for for that application would be 'copy stand' or camera support.
Nice straight forward design though.
You could also glue small pieces of sand paper on each side of the hinge if you can't find the rosin. Seems like the rosin would be cleaner looking than the sandpaper though.
