Overlap Twi'lek Headwrap for Lekku
Published
Introduction: Overlap Twi'lek Headwrap for Lekku
About: I like to sew and make things. Hopefully what I share can be helpful to others.
The main purpose of headwraps is to help secure the lekku onto your head, and also, cover the seam between your head and the lekku. I keep forgetting to take photos of the back view, I will add that later.
Step 1: Download the Overlap Pattern
This pattern is called the overlap pattern because the edges of this headwrap are longer than my previous pattern.
This will allow you to sew velcro onto the ends and secure it without using ties or grommets/lacing.
NOTES:
  • There are no seam allowances on this pattern piece. You will need to add seam allowances depending on what finishing methods you use.
  • I prefer my ear buds to sit at almost eye level.
Step 2: Print Out the Pattern
  • The pattern is two pages, because you will fold your fabric in half and cut the pattern on the fold.
  • When printing the pattern, make sure the box "Fit to page" is not checked.
Step 3: Assemble the Pattern
  • There are dotted lines on each pattern piece.
  • Align the pattern along those lines, matching up the pieces.
Step 4: Tape Your Pattern Together
  • Make sure to tape the pieces together on both the front and back sides.
  • This will make for a more secure pattern piece.
Step 5: Cut Out Your Pattern Piece
  • Cut out your pattern piece.
  • Now you have a base for modifying your pattern!
As mentioned before, there are no seam allowances added to this pattern piece.
  • I omit seam allowances because that changes depending on what kind of headwrap you make.
  • I prefer to use extra wide double fold bias tape to finish the raw edge of my headwraps.
  • Or, you can add a seam allowance to fold the edge over, and top stitch, to finish the seam.
Step 6: Check Your Pattern Piece
If you assembled two halves of the pattern, the center back should over lap like the above photo.
The exact amount of overlap will depend on many things:
  • how long your hair is
  • how you wear your lekku
  • the thickness of your finished headwrap
Don't sew the velcro onto the overlap area until you're done making the headwrap, trying it on periodically to check the fit.
Questions? Find me on instagram: @MadeByMaihien
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    It's such a great, simple pattern and I love all the decorative bits you've added :)
