Oversized Scissors (Stage Prop) by lime3D
Featured
I made it at TechShop http://www.techshop.ws
This project was made at TechShop - Detroit for a school play. They needed an oversized pair of scissors for the scene in the Wizard of Oz where the Cowardly Lion is getting "all prettied up" to see the Wizard. After designing the three-dimensional scissors in CAD (Autodesk Inventor is available to all TechShop members for free), it was easy to fabricate using the ShopBot CNC Router at TechShop.
Materials used:
   3/4" particle board (appropriate size for scale)
   (1) 1/4"-20 x 1-1/2" carriage bolt
   (1) 1/4"-20 nut
   (1) 1/4" fender washer
   (1) 1/4" washer
   latex house paint (for primer)
   spray paint (for finish colors)
Tools used:
   ShopBot
   Sanders
   Die grinder with flap sanding wheel (optional)
Step 1: Cut out the shapes
Using your CAM program (we use VCarve Pro), lay out the shapes for the ShopBot. You may download the .DXF of the scissor shape at http://www.lime3D.net/instructables/scissor.zip
Note: You will cut out two of the same exact part. Nest the file in any orientation to optimize the size of your 3/4" particle board workpiece.
You will see that the .DXF contains the profile shape, plus a boundary defining a pocket for the blade section. Cut the pocket 1/4" deep first. This will allow the two halves of the scissors to fasten together, and operate like their real-life counterparts.
Finish by cutting out the profiles and screw holes.
Pay no attention to the other shapes in the photos. Those are for two different projects we were cutting at the same time.
poofrabbit says: May 25, 2012. 12:09 AM
Congratulations on being a winner in the Big and Small contest!
lime3D (author) says: May 25, 2012. 4:15 AM
Thanks, it was a fun project!
Penolopy Bulnick says: May 16, 2012. 10:09 AM
Awesome! I love that it moves too!
lime3D (author) says: May 16, 2012. 10:27 AM
I'll try to see if I can post a photo from the play!
Penolopy Bulnick says: May 20, 2012. 7:58 PM
Ha! I love what you used the scissors for in the play!
Penolopy Bulnick says: May 16, 2012. 11:08 AM
Cool! Let me know when/if you do!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
