Well it's that time of the year again here in Southern California time to fill up the spa and break out the BBQs. This has become a yearly ritual as well as a scathing reminder that electricity is not free.
Any how my wife has been wanting to move in a greener direction and has been rather matter a fact about it as well. We now compost our organic waste and recycle that in to our garden. Her new kick was "How can we heat the spa without using the electronic heater?" She got up on the roof with 50ft of black hose and ran it back and forth a few times, hooked it to a pump and came up with the proof of concept. Yay! [The original idea was sourced from my coworker Gary which has a similar setup for his pool]
Today we decided to move from conceptual proof to full on production. This instructable will walk you through the process that we went through and try to help you avoid some of the gotchas that we found along the way. Hope you enjoy reading this as much as we enjoyed building/documenting this project.
Step 1: Parts list
For around $60 US you can build this neat little system using the following parts purchased at your local mega hardware store.
20ft of 1/2in diameter PVC pipe
1 x 1/2in 4-way Cross PVC Fitting
PVC cement for gluing PVC sections to 4 way fitting
500ft 1/2in diameter black drip irrigation hose
2 x drip irrigation to standard garden hose coupling
Around 200 outdoor 8in zip ties
2 x 25ft or so normal garden hoses to use as water feed and return (Not included in $60 est as we had 2 on hand)
1 water pump to push water up to the roof and through the solar coil for heating. (Also not included in $60 est as we had one on hand)
Step 2: Frame Setup
This step is simple. You take the 20ft of PVC pipe and cut it down to four 5ft long sections. Glue them each in to the 4 way fitting using blue PVC cement or some similar form of adhesive. Let it dry a bit and voila your framework is complete. Wish it was that easy creating frameworks at my day job! I'm a software developer if your wondering.
Step 3: Work area setup
Make sure you have room to move around the work area, as you will be doing a lot of walking (mostly in a circle). We setup a ladder with a pipe crossbeam which held the drip hose. This setup didn't work quite as well as we had hoped but did help keep the coil from getting horribly tangled. The frame was setup on a trash can that we filled part way with water to stabilize it from falling over.
The spool unwinding was managed by my wife for the most part and my son helped guide the hose while I walked in circles like a carnival mule.
Step 4: Spiral construction at a snails pace.
Photos don't show the first stages of construction as the idea to create an instructable from this project came slightly later in the project.
The hose was spun on to the frame starting at the middle and working outwards. We took a lead of around 6ft and attached to one leg of the frame, then we guided it in to the middle to begin the spiral. There were issues with kinks and worked out that at around 5in from the lip of the fitting the curve was easy enough that we could form the shape without kinking the hose. I marked out this 5 in using a marker and fastened the hose to the frame to begin the spiral. Working in chunks of around 4 to 5 rotations seems to work well until the later stages of construction. After each set of rotations you loosely fasten the hose using zip ties. Working from the last tightened point you guide the coil so that the hose sits evenly next to the previous loop. Too tight and it will overlap, too loose and it will cause grief on the next loop.
Step 5: Completion of the spiral
When we made it to the outer reaches of the spiral the weight of the hose was causing the frame to bow and was making it difficult to properly set the hose in relation to the proceeding loop. To remedy this we moved to the ground for the remaining loops. To do this we removed the remaining hose from our make shift spool mount and my wife walked the hose out while I followed behind her fastening the hose to the frame.
Step 6: Spiral deployment and finishing touches
Once the work was completed we carefully migrated the beast to the roof. We setup on the south facing side of the house. We fastened a rope to the center of the frame and tied it off on the north side of the house to prevent the coil from sliding down the roof. Once it was secured we connected the garden hose adapters to each of the leads coming from the coil and hooked up the cold water feed and hot water return hoses to the coil. (Note: Both our connector where female so we ran the return hose backward with the female end in the spa.) After the hoses were connected we hooked the cold water feed hose up a regular garden hose faucet and charged the system so to speak using the house hold water pressure. Once the water was completely through the system we connected the cold water feed to a pump in the spa and ran it for a test drive. Voila! it worked the pump was pumping water through the coil and it was returning to the spa.
I will update this instructable with thermal findings once we get a full day to test the system.
Cheers.
Step 7: Full Integration
This part of the process is completely custom based on your particular spa and how everything is setup. In our case the spa is on our back porch area next to the house so plumbing some PVC and running it up the wall was incredibly easy. We started by mapping out the current way the water cycles through the internal spa heating system. After some trial and error we ended up adding a 3/4" barbed T fitting inline with the internal heater pump. The return from the roof is feed back in to the spa system and enters the water through a small vent at the bottom of the spa. The pump that is currently installed is a small magnetic pump that is installed to simply help cycle the water through the siphon system. The overall flow is around 1GPM through the solar loop. A check valve was installed to help prevent water that had been heated being recycled through the coil and valves were installed on the outside of the spa to allow us to isolate the coil plumbing from the spa for maintenance. The rest of the plumbing was pretty straight forward, we went a little over the top by using pipe insulation but hey if your going to do it, you do it right! :)
Step 8: Results
Day #1
Time - Spa - Water from Solar coil
09:32am - 82.2 - 93.9
11:11am - 85.8 - 93.9
01:03pm - 91.0 - 101.1
01:57pm - 93.9 - 104.3 * Peak reading
03:37pm - 96.8 - 106.8
04:18pm - 98.6 - 103.8
Total increase over the time we monitored: 16.4 degrees fahrenheit
what size pump do you have?
why or how does the air get in the lines?
What if I took that dish, painted it black then wound your hose round and round in that? Our pool area gets full sun most of the day (in high summer it's more like a hot tub!) so I wouldn't have to mount it far from the pool pump at all.
What do y'all think of that?
anxious...
One suggestion would be to wrap the PEX in a pipe insulation of some kind to protect it from UV. PEX is great in areas where freezing temperatures are an issue and is extremely flexible.
you missed the mention of OUTDOOR zip ties in the parts listing - as they are less UV sensitive, they make a LOT of difference in the life expectancy of the fasteners.
Cheers
Note: Still working on the SpaDuino project and instructable to match...
Any amount you heat the water without electricity is money saved.
It would be a good Idea to bypass this system at night or on cloudy days because it will radiate heat into the air/space when the sun isn't shining.
Perhaps you could hook up a power measuring device (e.g., Kill-A-Watt) to your pump to indicate the energy use? Maybe compare with the energy consumption of the spa without solar warming?
Also, maybe put some reflective insulation panels underneath the coil on the roof to further heat them as well as isolate the heat from the roof?
I made something very similar for my wood fired hot tub. I was using it on the ground so that the warm water could passively thermosiphon into the tub. I found that I needed to insulate it from the ground as it would loose too much heat from conduction. In terms of pay off however the gains were pretty small. What I got from a days worth of solar heating could be achieved with an armload of wood in an hour.
11:11am - (85.8 - 93.9)?
01:03pm - (91.0 - 101.1)?
01:57pm - (93.9 - 104.3)? * Peak reading
03:37pm - (96.8 - 106.8)?
04:18pm - (98.6 - 103.8")?
Scales in celsius?
Cheers
I built a pool heater using basically the same idea a long time ago - I put 5 expanded 100' coils of 1/2" PVC (500 feet of it in total) into five 2'x8' wooden boxes connected in series, with glass 1 side mounted on backyard shed roof. The pool pump (3/4 hp 300 GPM) drove water through a controllable 'Y" connection (restrictor) - flow required regulation so that water would heat up sufficiently else it acted as radiator - the exact opposite of what was desired. This could have been a function of ambient temperature at my location (43 degrees N)
It worked reasonably well however its demise as Duplo above mentioned was UV from the sun - even with the piping behind glass it started to break down (became brittle and developed pinhole leaks) after 5 or 6 years and requiring many patches, too many :-), and I scrapped it.
I'd strongly suggest using UV stabilzed PVC pipe - much more expensive though
How hot did the water get & other stats?
it would be easier just use the UV stabilzed PVC if you are going build one - either that or make the PVC pipe easily replaceable - my design did not allow for this - live and learn - Petastream's design would be better suited to periodic replacement IMO
as to heat added - I'd guess delta between inflow and outflow was about 7 degrees C - not huge but noticeable considering my pool is heated only by the sun.
the roof temperature (under the shingles) hit ~80 C on a nice sunny day
Also, how strong in the pump you used? (GPM)
