Well it's that time of the year again here in Southern California time to fill up the spa and break out the BBQs. This has become a yearly ritual as well as a scathing reminder that electricity is not free.
Any how my wife has been wanting to move in a greener direction and has been rather matter a fact about it as well. We now compost our organic waste and recycle that in to our garden. Her new kick was "How can we heat the spa without using the electronic heater?" She got up on the roof with 50ft of black hose and ran it back and forth a few times, hooked it to a pump and came up with the proof of concept. Yay! [The original idea was sourced from my coworker Gary which has a similar setup for his pool]
Today we decided to move from conceptual proof to full on production. This instructable will walk you through the process that we went through and try to help you avoid some of the gotchas that we found along the way. Hope you enjoy reading this as much as we enjoyed building/documenting this project.
Step 1: Parts list
For around $60 US you can build this neat little system using the following parts purchased at your local mega hardware store.
20ft of 1/2in diameter PVC pipe
1 x 1/2in 4-way Cross PVC Fitting
PVC cement for gluing PVC sections to 4 way fitting
500ft 1/2in diameter black drip irrigation hose
2 x drip irrigation to standard garden hose coupling
Around 200 outdoor 8in zip ties
2 x 25ft or so normal garden hoses to use as water feed and return (Not included in $60 est as we had 2 on hand)
1 water pump to push water up to the roof and through the solar coil for heating. (Also not included in $60 est as we had one on hand)
sparkydave says: May 2, 2012. 7:55 PM
I have made one of these but used a small 12 volt water pump and small 12 volt solar PV panel to run it. that way it doesnt cost anything at all to run and the pump only runs when there is sun! (both purchased on eBay for about $70 combined)
bblaske in reply to sparkydaveJun 9, 2013. 2:25 AM
Could you send some links to the things you have purchased? Thanks!
bblaske says: Jun 9, 2013. 2:24 AM
Hi! Really cool idea! Could you please give some hints about the pump that would be required to push the water through the system? Thanks!
7808 says: May 27, 2013. 9:30 AM
very cool, wish my pool and or spa were a little closer to the south side of my house. i would really like to try this with my 16ft round above ground pool and maybe just lay the spiral on some corregated sheet metal roof piece or somthing because my pool is just too far from my house . what was the ambient temps on the days you took those readings? im wondering if the sun up here in MN will not work so well, also we just plain dont have as many sunny days so im not sure its worth building
srobbins813 says: Apr 3, 2013. 2:47 PM
I have built this solar spa heater, and it works even better then I thought it would. I have also add a timer to turn the pump on and off daily, The thing that is not working well is each morning before the pump comes on I have to go out and prime the heater. Both the intake and discharge lines are under water so that air can not enter the system, but each day when running the garden hose into the system theres air. the pump I have can push up to 9' and the solar heater is only at 8' or less.
what size pump do you have?
why or how does the air get in the lines?
Jaygo says: Mar 31, 2013. 5:08 AM
I live in East Texas- Beacoup sunshine but still need a heater for early spring and fall's shorter sun hours. This (very nice instructable, thanks!) gives me an idea but I would like to trot it through here. I have one of those old humungous satellite antennas of years past, right behind the pool as it happens.
What if I took that dish, painted it black then wound your hose round and round in that? Our pool area gets full sun most of the day (in high summer it's more like a hot tub!) so I wouldn't have to mount it far from the pool pump at all.
What do y'all think of that?
LancePenney says: Aug 18, 2012. 2:56 PM
According to your data at peak output which is a spa temp of 93.9F (can be used as an input temp), an output temp of 104.3F and a flow rate of 1GPM, you were raising the temp of 3.79 kilograms of water by 5.78C every minute. That would be a total energy increase (using q=mc(delta t)) of 91 509 joules to your spa every minute. Divide that by 60 seconds you get a power output of 1525 watts. Very impressive.
kellyawilkins says: May 1, 2012. 2:15 AM
Did anyone consider the "unbreakable" PEX for hydronic systems? the best of plastic and metal And cost yay! I saw it at the hardware store and in the farmtek catalog.
anxious...
danielmitchem in reply to kellyawilkinsJun 12, 2012. 8:26 AM
PEX is a great type of plumbing. The only problem with it is its susceptibility to breakdown due to UV. Anytime PEX is run, it should be run where sunlight can't affect it.
One suggestion would be to wrap the PEX in a pipe insulation of some kind to protect it from UV. PEX is great in areas where freezing temperatures are an issue and is extremely flexible.
prphntm in reply to danielmitchemJul 21, 2012. 5:27 AM
I've had mild success running a PEX line inside of a slightly larger schedule 10 PVC pipe (used for low pressure drains) when it has to be in a UV exposed area
guitarpicker7 says: Jun 4, 2012. 9:38 PM
comment on ganaanaq2 post:
you missed the mention of OUTDOOR zip ties in the parts listing - as they are less UV sensitive, they make a LOT of difference in the life expectancy of the fasteners.
petastream (author) in reply to guitarpicker7Jun 7, 2012. 10:21 AM
Yes, we did use Outdoor zip ties. We will be updating the list as well as pictures for all the work we have done to it since the original posting.
petastream (author) says: May 5, 2012. 9:42 AM
Figures after we build this solar project the sun goes in to hiding for a week and a half. Anyhow today looks like it will be clear yet busy for us. I'll take a new sample set tomorrow if the sun stays out!
Cheers
petastream (author) in reply to petastreamMay 13, 2012. 10:32 PM
We had a good week of sun this week, we were able to raise the Spa temp from ground temp of around 72 degrees fahrenheit to a peak of 106 degrees fahrenheit over a 3 day period. Not bad :)
Note: Still working on the SpaDuino project and instructable to match...
cowboynwh says: Apr 30, 2012. 5:48 AM
Do you turn the heaters on at night and use this as a supplement heat during the day?
sconner1 in reply to cowboynwhMay 2, 2012. 11:19 AM
If you want hotter water than the sun can provide at any given time, just boost with the electric heater.
Any amount you heat the water without electricity is money saved.
It would be a good Idea to bypass this system at night or on cloudy days because it will radiate heat into the air/space when the sun isn't shining.
petastream (author) in reply to cowboynwhApr 30, 2012. 6:45 PM
We plan on only using the heater as a last resort, our target temp is around 102 degrees fahrenhieht in the spa.
gana_anaq2 says: May 2, 2012. 8:27 AM
i like the project ideea , simple and practical. I see only a hidden mistake, from the fixing the plastic tube. You used plastic self locking clips and from my experience this after a few years of beeing kept on the sun , the plastic become very hard and fragile ... so i sugest to put a metalic wire between the pipe and the metalic cross. Otherwise it is possible to se one time a big black flower in the roof :))
waylonis says: Apr 30, 2012. 11:40 PM
Very nice!
Perhaps you could hook up a power measuring device (e.g., Kill-A-Watt) to your pump to indicate the energy use? Maybe compare with the energy consumption of the spa without solar warming?
Also, maybe put some reflective insulation panels underneath the coil on the roof to further heat them as well as isolate the heat from the roof?
veloboy says: Apr 30, 2012. 8:30 PM
NIce job!
I made something very similar for my wood fired hot tub.  I was using it on the ground so that the warm water could passively thermosiphon into the tub. I found that I needed to insulate it from the ground as it would loose too much heat from conduction.  In terms of pay off however the gains were pretty small. What I got from a days worth of solar heating could be achieved with an armload of wood in an hour.
Victor Moser says: Apr 29, 2012. 5:46 PM
"09:32am - (82.2 - 93.9)?
11:11am - (85.8 - 93.9)?
01:03pm - (91.0 - 101.1)?
01:57pm - (93.9 - 104.3)? * Peak reading
03:37pm - (96.8 - 106.8)?
04:18pm - (98.6 - 103.8")?
Scales in celsius?
romulopericles in reply to Victor MoserApr 29, 2012. 6:50 PM
Total increase over the time we monitored: 16.4 degrees fahrenheit
Victor Moser in reply to romulopericlesApr 29, 2012. 7:06 PM
But what was the final temperature?
petastream (author) in reply to Victor MoserApr 29, 2012. 8:24 PM
In our initial set of readings all values are in fahrenheit and the final reading of the day was 98.6 in the spa with water coming from the coil at 103.8. I am currently working on the Netduino based project that will log this information to an SD card for analysis. If anyone is interested there is some initial hack code up at GitHub. I will be posting a follow up instructable regarding this project in the near future.
Cheers
Victor Moser in reply to petastreamApr 30, 2012. 4:07 PM
Wonder. I await the final results!
petastream (author) in reply to Victor MoserApr 30, 2012. 6:43 PM
We are waiting for a good sunny day here. Now that the project is ready the clouds moved in. Inevitable I suppose.
BIOhazard_inc in reply to Victor MoserApr 30, 2012. 5:18 PM
That si pretty cool
BIOhazard_inc in reply to BIOhazard_incApr 30, 2012. 5:18 PM
Oops I mean "That is preety cool"
msmith4 says: Apr 29, 2012. 11:23 PM
I have been meaning to do this for a while, was looking for a good way to construct the framework, might give this a go, if I can find a + piece. How many liters to you get from your coil? I would also be a little concerned about putting a more secure attachment on the roof for windy days.
gcai_fwb says: Apr 29, 2012. 9:57 AM
good instructable!
I built a pool heater using basically the same idea a long time ago - I put 5 expanded 100' coils of 1/2" PVC (500 feet of it in total) into five 2'x8' wooden boxes connected in series, with glass 1 side mounted on backyard shed roof. The pool pump (3/4 hp 300 GPM) drove water through a controllable 'Y" connection (restrictor) - flow required regulation so that water would heat up sufficiently else it acted as radiator - the exact opposite of what was desired. This could have been a function of ambient temperature at my location (43 degrees N)
It worked reasonably well however its demise as Duplo above mentioned was UV from the sun - even with the piping behind glass it started to break down (became brittle and developed pinhole leaks) after 5 or 6 years and requiring many patches, too many :-), and I scrapped it.
I'd strongly suggest using UV stabilzed PVC pipe - much more expensive though
petastream (author) in reply to gcai_fwbApr 29, 2012. 8:47 PM
The tubing we are using for the coil is this I used it once before for a drip system at my parents home about 3 years ago and that system seems to be doing fine. We are also pushing very low volume through this system, using the new magnetic pump the flow is around 1GPM which allows us to cycle 3/4 of entire spa through the system during the sunny hours of the day.
flyingpuppy in reply to gcai_fwbApr 29, 2012. 11:08 AM
Would spraying the pipe/hose with UV protectant spray keep it from breaking down? Would it cut heat absorption?
How hot did the water get & other stats?
gcai_fwb in reply to flyingpuppyApr 29, 2012. 1:59 PM
no idea if UV protectant would help - build one, treat it and wait 5-6 years :-)
it would be easier just use the UV stabilzed PVC if you are going build one - either that or make the PVC pipe easily replaceable - my design did not allow for this - live and learn - Petastream's design would be better suited to periodic replacement IMO
as to heat added - I'd guess delta between inflow and outflow was about 7 degrees C - not huge but noticeable considering my pool is heated only by the sun.
the roof temperature (under the shingles) hit ~80 C on a nice sunny day
danzo321 says: Apr 29, 2012. 10:20 AM
Seems like you could use the water pressure in the system (plus gravity) to fill hottub with hot water as you push in cold water for the next time you want some hot. OR are you re-heating what has already been heated? I just know if I turn on my garden hose, first flow would kill my plants it's so hot.
petastream (author) in reply to danzo321Apr 29, 2012. 8:39 PM
We run the water through the system when we first fill the spa up, after that we use the system to recirculate the water during the day. If we leave the water stagnate on the roof for a few hours then turn the system on the water coming from the return line is around 150 fahrenheit.
ferralll says: Apr 29, 2012. 9:35 AM
Have you had any problems with vapor lock in your heating coil?
Also, how strong in the pump you used? (GPM)
kyle.marsh in reply to ferralllApr 29, 2012. 6:26 PM
Looks like his pump is inside the hot tub pushing rather than above it pulling; I think that means that there shouldn't be any vapor lock problems at all. If you wanted to put the pump up on the roof so you didn't have it kicking around inside the tub you might run into some trouble.
petastream (author) in reply to kyle.marshApr 29, 2012. 8:28 PM
The initial run we used the submersible pump to help the water cycle through the system. That pump was pumping at around 1.25 GPM which yielded the results seen on the last step of the instructable. We have since moved to a lighter duty pump and have tied the solar system in to the internal spa plumbing. This part of the project was completed today and I will be appending that process to this instructable.
chaitanyak says: Apr 29, 2012. 6:32 PM
i dont have a pool but will try it anyway.. for one of the bathrooms
MsLynne707 says: Apr 29, 2012. 1:55 PM
As good as this is about 20 yrs ago, I built a system quite similar with the pvc and glass and it worked great for about 3-4 yrs and then we went to a change and used a old hot water heater stripped down without the jacket and we put tha into a box with mirrors inside to reflect the heat onto the tank and we had this for about 7yrs after that we incorporated the whole system together and we now have way more HOT WATER than we ever can use so just keep up the great work and continue on the joirney towards an ALL GREEN ENVIROMENT.......
mrfoltz says: Apr 29, 2012. 1:28 PM
love it when I see posts like this! Good for you! And your Wife and child!!! ;0]
triumphman says: Apr 29, 2012. 11:57 AM
I would love to pre -heat my hot water for showers & sinks! Most hot water is used for these two uses. My oil furnace is a full time /always on system! It wastes a lot oil oil! Do you think i could rig up a coil for a pre-heater? It woul really save a lot of oil! The cost of home heating oil is never going to go down! My roof slope looks just like yours! I just personally put new shingles up there! That goodness for compressor powered nail guns!
buju357 says: Apr 29, 2012. 11:04 AM
polycarbonate will last 1-2 years in the sun then disintegrate , rather use 4mm perspex , that has +- 10 years life span in the sun , or best to use 10 mm glass , life span will be 20 -30 years.
I have a very similar system running for 2 years now , I use 1/4 inch garden irrigation hose to heat water for the washing machine , basically push cold water from the tap into the pipes and return it to the inlet of the washing machine , best temperature Ive got is 55 deg cel.
After much r&d , the problem is pressure , combined with heat it easily bursts the pipes or connection so a pressure relief valve is mandatory.
Well done , and lets all keep up the green movement.
poco424 says: Apr 29, 2012. 10:50 AM
By going to yard sales one can pick up two 52" patio tables one can disassemble for the glass. Using this glass one can make one's own trapped air space for this assembly cheaply and easily. The pvc pipe and cable ties are not necessary in that the black piping can be laid directly on the glass and glued to it and the return hose can be taken directly out of the umbrella hole.
A note of caution: the trick to working with tempered glass is that while one can almost beat on the face of the glass with a hammer the edges are especially tender. Protecting the edges until the assembly is placed on the roof requires attention.
Also, there are table tops with holes in the center and those without. One without a hole would probably be best for the lower glass.
Just an idea. Used to wholesale shaped glass most of which was tempered glass table tops for patio tables.
Duplo for Daddies says: Apr 28, 2012. 1:02 AM
Nice work. Comment about the polycarbonate. Glass has an unbeatable weather resistance, poly does not. My experience is that the more expensive weather resistance poly will empty your wallet. Poly is definitely more convenient, but if your lucky you might come by a big round glass table, which most likely is made by tempered glass. Safe and durable!
dkiehl in reply to Duplo for DaddiesApr 29, 2012. 7:58 AM
The glass table is an awesome idea! I wonder whether glass sliding doors are tempered glass or are as thick? I plan on building a solar heater using a spot Fresnel lens to super heat my insulated box. Many companies have Tungsten carbide scraps from machine shops. Tungsten will easily take 4,000 F, so as long as I have enough air flow I should avoid any melting or combustion byproducts. I have also thought about using the lens to turn the water into steam to rotate permanent magnet generator and use the left over steam as a heat source. The only problem is figuring out the amount of expansion this would require.
petastream (author) says: Apr 23, 2012. 11:15 AM
Just got confirmation that the parts for the followup to this article are inbound. Will be adding data logging and automatic control system to this system using a NetDuino Plus and a handful of other components. Before anyone asks, I chose NetDuino over Arduino simply due to the fact I use DotNet every day at work. Either system would work and I have no personal preference other then current language of the moment. :)
NetDuino: http://netduino.com/
Arduino: http://www.arduino.cc/
I
 will post the link to the instructable once it's ready
Cheers
gomiboy says: Apr 22, 2012. 10:08 AM
This looks great! We were talking about putting in a spa and how expensive they are to run. I'll be following this to see if it's feasible for us (in Virginia). One thing to consider if you need to boost the temperature is to build a glass case/cover for it. You can likely find large panes of glass from Freecycle (www.freecycle.org to see if there's an active community in your area). I've gotten materials for a yet-to-be-built greenhouse that way. Good luck!
petastream (author) in reply to gomiboyApr 22, 2012. 5:45 PM
Great idea in fact, trapping the air and heating the ambient area makes alot of sense.
rimar2000 in reply to gomiboyApr 22, 2012. 4:21 PM
I agree about the box. Maybe polycarbonate is cheaper and safer than glass.
rimar2000 in reply to rimar2000Apr 22, 2012. 4:21 PM
...and easier to work with it.
Lasrin says: Apr 22, 2012. 3:54 PM
Awesome! I can't wait to see how this turns out.
GreenPowerScience (youtube) has some more details on this kind of thing..
http://www.youtube.com/watch?v=St-0HWKAY4k&feature=relmfu
breumer says: Apr 22, 2012. 12:39 PM
5 Stars! Awesome!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
