Any how my wife has been wanting to move in a greener direction and has been rather matter a fact about it as well. We now compost our organic waste and recycle that in to our garden. Her new kick was "How can we heat the spa without using the electronic heater?" She got up on the roof with 50ft of black hose and ran it back and forth a few times, hooked it to a pump and came up with the proof of concept. Yay! [The original idea was sourced from my coworker Gary which has a similar setup for his pool]
Today we decided to move from conceptual proof to full on production. This instructable will walk you through the process that we went through and try to help you avoid some of the gotchas that we found along the way. Hope you enjoy reading this as much as we enjoyed building/documenting this project.
Remove these ads by
Signing UpStep 1: Parts list
20ft of 1/2in diameter PVC pipe
1 x 1/2in 4-way Cross PVC Fitting
PVC cement for gluing PVC sections to 4 way fitting
500ft 1/2in diameter black drip irrigation hose
2 x drip irrigation to standard garden hose coupling
Around 200 outdoor 8in zip ties
2 x 25ft or so normal garden hoses to use as water feed and return (Not included in $60 est as we had 2 on hand)
1 water pump to push water up to the roof and through the solar coil for heating. (Also not included in $60 est as we had one on hand)
Visit Our Store »
Go Pro Today »
what size pump do you have?
why or how does the air get in the lines?
What if I took that dish, painted it black then wound your hose round and round in that? Our pool area gets full sun most of the day (in high summer it's more like a hot tub!) so I wouldn't have to mount it far from the pool pump at all.
What do y'all think of that?
anxious...
One suggestion would be to wrap the PEX in a pipe insulation of some kind to protect it from UV. PEX is great in areas where freezing temperatures are an issue and is extremely flexible.
you missed the mention of OUTDOOR zip ties in the parts listing - as they are less UV sensitive, they make a LOT of difference in the life expectancy of the fasteners.
Cheers
Note: Still working on the SpaDuino project and instructable to match...
Any amount you heat the water without electricity is money saved.
It would be a good Idea to bypass this system at night or on cloudy days because it will radiate heat into the air/space when the sun isn't shining.
Perhaps you could hook up a power measuring device (e.g., Kill-A-Watt) to your pump to indicate the energy use? Maybe compare with the energy consumption of the spa without solar warming?
Also, maybe put some reflective insulation panels underneath the coil on the roof to further heat them as well as isolate the heat from the roof?
I made something very similar for my wood fired hot tub. I was using it on the ground so that the warm water could passively thermosiphon into the tub. I found that I needed to insulate it from the ground as it would loose too much heat from conduction. In terms of pay off however the gains were pretty small. What I got from a days worth of solar heating could be achieved with an armload of wood in an hour.
11:11am - (85.8 - 93.9)?
01:03pm - (91.0 - 101.1)?
01:57pm - (93.9 - 104.3)? * Peak reading
03:37pm - (96.8 - 106.8)?
04:18pm - (98.6 - 103.8")?
Scales in celsius?
Total increase over the time we monitored: 16.4 degrees fahrenheit
Cheers
I built a pool heater using basically the same idea a long time ago - I put 5 expanded 100' coils of 1/2" PVC (500 feet of it in total) into five 2'x8' wooden boxes connected in series, with glass 1 side mounted on backyard shed roof. The pool pump (3/4 hp 300 GPM) drove water through a controllable 'Y" connection (restrictor) - flow required regulation so that water would heat up sufficiently else it acted as radiator - the exact opposite of what was desired. This could have been a function of ambient temperature at my location (43 degrees N)
It worked reasonably well however its demise as Duplo above mentioned was UV from the sun - even with the piping behind glass it started to break down (became brittle and developed pinhole leaks) after 5 or 6 years and requiring many patches, too many :-), and I scrapped it.
I'd strongly suggest using UV stabilzed PVC pipe - much more expensive though
How hot did the water get & other stats?
it would be easier just use the UV stabilzed PVC if you are going build one - either that or make the PVC pipe easily replaceable - my design did not allow for this - live and learn - Petastream's design would be better suited to periodic replacement IMO
as to heat added - I'd guess delta between inflow and outflow was about 7 degrees C - not huge but noticeable considering my pool is heated only by the sun.
the roof temperature (under the shingles) hit ~80 C on a nice sunny day
Also, how strong in the pump you used? (GPM)
