I did some googling, and found the easiest way was to use three layers of material (plastic or card) simple cut out, sprayed, and stuck together.
I set out planning to trace some screen shots/web images, to make a template, however, along the way i stumbled accross, Matt Munson who had a wide range of templates free for personal use.
Update - Matt Munson commented on this Instructable with the news that he had been prompted to add the files to his site again.
You can access all the templates here - www.mattmunson.com/props/
Thank you Matt, for allowing access again, so everyone can make what is one of the best props out there.
I am not providing the templates here, as he explains that he had previous problems with people using the templates for professional gain.
So, here is how i did it.
You need,
- Some world famous, gmjboard (super dense thick strawboard/cardboard)
- Some thin plastic transparencies
- a household inkjet printer
- a good scalpel and stanley knife
- Some double sided tape
- a sharpie
- some silver spray paint
Remove these ads by
Signing UpStep 1Get cutting.
Print out some of the templates, or design your own if your feeling creative, Its very easy to draw a simple design.
Stick the paper templates down to your selected board, My suggestions are to use either card, or plastiboard/styrene, both these can be cut using the stanley knife. Though the card is a much easier material to work with, it does give a slightly more rough finish.
Take your time with the cutting, many strokes, and less pressure is the way to go.
The corners are most difficult, but i found if i used the scalpel, and slowly nipped away around the corner it gave a cleaner better cut.
:D Have fun!!!!!!!
Someone pointed me to this discussion, and I have re-posted all of my templates for ALL of the padds I ever drew, and also put up a bunch of graphics that I made over the years.
As always, my only request is that these are used for personal use, not financial gain.
you can find everything you need here:
I forget what the various thicknesses are for the different padds. If I figure that out, or can find my notes somewhere, I will post that too.
Thanks again for all of the interest in my templates. I hope you make great use of them!!!
I had read and seen the trouble you originally had with people stealing your designs and selling them, which is why I specifically chose not to report the files here. Instead telling people to go to your site.
Its great that you have decided to re-host the templates.
Thanks again,
gmjhowe
thanks
Sean
No, on second thought, the pinnacle would be to make a working padd.
