3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
P.A.D.D from star trek voyager
Step 3The screen
The screen
Next is to print off the screens and buttons, luckily for you, i designed these my self, which means im more than happy to provide pdf files, which you will see just below.
I printed these on a professional high end large format inkjet printer, i suggest printing them on photopaper, on your best quality setting.
Next we need to cut the transparency down to size, the stuff i used had a red layer on it, which i peeled off, cut it to a rough size, with room around the outside for double sided tape.
Using double sided tape, along the edge of the printed screen and transparency carefully stick all the pieces together. With the transparency ontop of the printed sheet.
Check to alignment with the top section.
buttons.pdf(490x134) 487 KB
1.pdf(492x318) 3 MB
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
