3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
P.A.D.D from star trek voyager
Step 4Stick on the front and back
I placed more double sided tape around the edge of the front, and stuck this in place.
I then placed another two large strips on the back plate, aligned it with the front plate properly, and stuck this on.
You could easily use glue for this, but the double sided tape works just fine.
Finally, i a sticker for use on the back. I printed onto a normal sticker paper, and then carefully placed it centred on the back, about 15mm from the bottom. You will find a .pdf file of the sticker in this step, which also had a black outline to help with positioning!
backsticker.pdf(795x582) 499 KB
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
