PAPER BOOMERANG
Published
Introduction: PAPER BOOMERANG
In the name of Allah.
Peace be upon you and Allah’s mercy and blessings. This is my first Participation in this site :). The paper boomerang: This is really cool origami boomerang,You throw it away from you and it will fly back towards you!
Step 1:
start with a (4,25inch x 11inch),(10,75cm x 27,9cm)paper.Printer paper works fine for this origami.
Step 2:
Fload paper in half on the Horizontal axis.
Step 3:
Fold both sides to about 1mm from the center. We'll have to fold the paper in half again later and the 1mm prevents the paper from overlapping.
Step 4:
Fold the paper in half, bringing the top down to the bottom. Crease well.
Step 5:
Fold the top right and left corners to the center. Crease well and unfold.
Step 6:
Unfold paper and rotate.
Step 7:
Unfold the bottom half of the paper.
Step 8:
Make a small valley fold where indicated below.
Step 9:
Recrease where indicated into valley folds.
Step 10:
Now recrease where indicated into mountain folds.
Step 11:
Fold up the upper half of the paper so that it is vertical or perpendicular to the table.
Now hold on to the left side of the paper and move the right side of the paper clockwise until the paper forms a "number 7" shape.
Step 12:
Fold the lower half of the paper to the right as shown below.
Step 13:
Fold down the top half as shown.
Step 14:
Now, we're going to make another valley fold to close up the paper. As you do so, you'll need to tuck the tip into the upper right corner pocket.
Here's the tip getting tucked into the upper right corner pocket. Make sure the paper stays flat as you slide it all the way into the pocket.
Step 15:
Almost done! Next we need to work on the bottom half of the paper.
Step 16:
Pry the paper open a little. Fold both corners to the center. Crease well and unfold.
Step 17:
Use the crease to make an inside reverse fold on the left side only.
Step 18:
Now tuck the right tip into the left pocket. Make sure the paper stays flat as you slide the tip in.
Step 19:
We'll now do the same for the top end of the paper.
Step 20:
Pry paper open slightly and fold both sides to the center. Crease well and unfold.
Step 21:
Make an inside reverse fold on the top side.
Step 22:
Now tuck the tip into the pocket.
Step 23:
Now your paper boomerang is complete! and Praise be to Allah .
Step 24:
Hold it in the middle with your thumb on top and index finger on the bottom. Throw it by twisting your wrist (not your arm), like you're throwing a frisbee, upwards and away from you.
Step 25: The Right Face to Throw It
You must throw it with the front face like in the photo.
  • Stick It! Contest
    Stick It! Contest
  • Woodworking Contest
    Woodworking Contest
  • Pets Challenge
    Pets Challenge
10 Comments
Cool! I always thought paper was not heavy enough for a boomerang.
Welcome Thank you for your comment brother.
oussama oux, should I attach a paperclip on the end to make it fly better? I made it out of cutted A4 80mg paper
and the A4 paper, and printer paper it's good for fly
welcome no its not Important
I am frustraited. My one doesnt fly. I folded it properly. ughdyffgc
how do you throw it ?
look part 25
