Introduction: PARTY FAVOUR CONTAINERS From Plastic Bottles
At the DIY Divas upholstered ottoman workshop yesterday we were discussed recycling. One of the ladies mentioned how to make party favours using the base of a plastic bottle. Not quite understanding what she meant, I experimented with different ways and lo and behold, you can make fantastic party favour containers with a plastic bottle. Here is my first attempt. A bright candy pink party favour with a black butterfly.
Step 1:
You can use any size of plastic bottle depending on whether you want small or large party favour containers. I am using a 2-litre plastic bottle. You need to cut off the top section of the bottle as shown left and you can use the marks on the bottle as a guide.
Some bottles have vertical indents and you can use these to cut lines down to the base. If your bottle doesn't have any indents, divide into 5 equal sections.
Keep your cut a distance of 3cm away from the line that marks the cup shape at the bottom of the bottle. Don't worry if you get it wrong the first time - you can use the base for another project.
Step 2:
Use a pair of scissors to curve the top corners of the five cut sections.
Step 3:
Before you carry on, close the top to make sure the cut is in the right place.
You can still make adjustments if the cut is too short.
Step 4:
Rust-Oleum 2X spray paint comes in beautiful colours and can now be sprayed onto plastic. Only spray on a light, even coat to prevent runs and then let this dry.
Once dry, fold over the sections and add your desired embellishment - attaching on the top of one section with hot glue.
You can even decoupage your party favours with fabric or wrapping paper.
