PC Fan Ice Cooler
10,902
58
5
Published
Introduction: PC Fan Ice Cooler
About: Comment what I should make. I will try to make anything with what I have.
This is how to make a nice cold PC fan cooler.
Step 1: What You Need
To make the PC fan ice cooler you need-
1. A circular tube that a PC fan can fit Nicely on. (I used a lava lamp box)
2. Tape
3. Extra Wires
4. A 12 volt wall adapter
Step 2: Attach the Wires
Attach the PC fan wires to the two extra wires
Step 3: Place It On
Place the PC fan on the circular Tube.
Step 4: Tape It
Tape around the PC fan. Make sure no air escapes.
Step 5: Tape the Wires
Tape the wires so they run down the tube.
Step 6: Twist One of the Extra Wires
Tape one of the wires around the outside part of the adapter
Step 7: Tape It So It Does Not Come Off
Make sure you tape it so it won't come off
Step 8: The Other Wire
Place the other wire into the wall adapters hole.
Step 9: Tape It
Tape it so it won't move
Step 10: Tape It to the Circular Tube
Tape it onto the tube so it is not hanging off the tube.
Step 11: It Should Look Like This So Far
But we're not done :)
Step 12: Wrap Paper Around It
Wrap paper around it so the wires won't show and it will look better.
Step 13: Open the Bottom Off the Tube
When the bottom of the tube is open place a glass of ice on the bottom so the fan blows cold ice out the top.
Step 14: Place the Tube Back On
When the tube goes back on the glass will not be visible.
Step 15: Plug It In
When it is plugged in it will blast cold air. hope you liked the project :)
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    a very 'cool' project ;)
    I was going rip on this for the connections and a few other things then I checked your profile and saw that you are only 15. That's pretty cool that someone your age likes this kind of stuff. I also noticed you are new to instructables and you've posted 4 projects already. My advice would be to slow down, spend a little more time on documentation / presentation, and most importantly consider safety. Anyway, nice job and welcome to instructables.
    Well said by @mtairymd. You should be a little slow and take more time in making your written matter more detailed. Anyways, good one I must say! Even I share the same age group as yours and interested in the same stuff as well :)
    Dude solder a jack on that bad boy, telling people to do that is dangerous especially using masking tape and not electrical tape. Even if it is low amperage some kid might go trying this on something else.
