loading
Step 2: Costruction: board and connector
A power connector was salvaged from a 3.5" floppy drive. A scrap of copper clad board was dug up from somewhere.
A piece of board slightly wider than the connector was cut to size, edges smoothed and holes drilled to accept the connector.
<p>Hi,</p><p>What changes must be required if we need to limit the current to about 1.5-1.8 amperes?</p>
Thanks! I needed this circuit. I put a 10k potentiometer in place of R5 which I think is useful.<br><br>I run this circuit with the 5V off my USB port. I didn't have to make any modifications except to make sure the transistors remain biased (changing value of the R5 pot).
By the way, I found a circuit of the same kind<a rel="nofollow" href="http://en.wikipedia.org/wiki/Current_limiting#In_electronic_power_circuits">here on wikipedia</a><br/>Any comment from experts ? :-)<br/>
It has a sensing resistor in series with the output. It can drop up to Vbe of the sensing transistor - around 600 mV - before current limiting takes place. It passes the full limiting current into a short circuit. This type of current limiting will be appropriate for an audio amplifier, for example. My circuit is intended to be a sort of electronic fuse which cuts off current when a short circuit is applied, and recover automatically when the short is removed.
so its like a self-reseting circuit breaker?
so this is kinda like a self activating fuse type of thing ,right?
A length of thin wire, or a small resistor (2.2 ohms, 1/4 Watt) will work as a self activating fuse.<br/><br/>This circuit works as a self-<strong>resetting</strong> fuse.<br/>
ah...yes self reseting fuse pretty neat...i might make this for some of my projects
Couldn't you just use a fuse? They're much simpler a circuit :) Or am I missing the whole point?
Of course you can. But then I tend to get tired of changing fuses pretty quickly.
PTC self resetting fuse(thermal breaker)
I like the idea of a trimpot (on R1 ?) to select the max current but I have trouble to find which resistor values are needed. I understood that the maximum current depend of &quot; the gain times base current before it drops voltage &quot;. But it is not clear how to calculate it. Any clue ?<br/>Can I find it empirically from the voltage at R1 ends ? (But then a gain of 50 in Q1 and the value you give will mean: Vr1= 470*.22/50 = 2V but that look a bit too few)<br/>By the way what is the role of R5/(R4+R5) ? It look important to make the whole thing work but you did not say why :&quot;That resistor at the output, originally 10K, changed to 36K, <strong>had to be changed</strong> to 22K.&quot; (in 8)<br/>
10K - onset of current limiting too high 36K - circuit would not turn on with load 22K - current limiting around twice load current. I have modified step 8 accordingly.
From my experience the PC supply is very noisy and often considerably over voltage. The 5V regulator would give a clean supply if powered from PC 12V. But it would not keep the PC from resetting if you shorted the output. <br/><br/>The regulator does have overtemp and short circuit protection but the input current would still spike.<br/><br/>I describe a different current limiting circuit on my site in case you are interested.<br/><a rel="nofollow" href="http://www.uchobby.com/index.php/2006/11/12/current-limited-pc-power/">http://www.uchobby.com/index.php/2006/11/12/current-limited-pc-power/</a><br/>
The computer power supply pre-regulates the power. If you want 5 volts, pull off of a red wire instead of a yellow wire. Red to ground is 5 volts and yellow to ground is 12. The orange wire if available is even regulated at 3.3 for you. The point of his design is not as a voltage regulator but as a very low current overload protector. Fuses are normally rated higher than this and with no way to adjust and have to be replaced. Another advantage to this is that one could change the resistor with a trimpot to make a variable trip overload protector.
I have to admit to being more than a little puzzled here. Couldn't we drop about four components by using a 7805 regulator, with a series resistor on it's output? That should limit the current and give us a +5v supply. Probably wouldn't even need the bypass caps, I expect the output of a PC power supply is pretty stable.
1. I need a 12 V supply. 2. Series resistors impose voltage drops. 3. It has to be protected from short circuits.
The simple way is a PTC fuse. They are self resetting and simple devices.<br/><a rel="nofollow" href="http://www.littelfuse.com/resettable_fuse.html">Little fuse</a><br/>
So this circuit prevents a short from causing a shut down and loss of data in your PC. But if I want more current I can just plug directly into the floppy power connector, right? Some power supplies offer 5v @ 30A for example. So if I want to draw 10 Amps or so, I just have to make sure I never short it otherwise my PC is damaged. Am i getting this right?
Right. But I think if you need 10A on a regular basis you'll be better off investing in a separate power supply. A 12V, 7AH lead acid battery kept charged by a small (500 ma) wall wart is a good option, too, if you need it only intermittently.
dfowler7437says:<br/>I did an article about a current limiter to use with the PC supply at the following link. This limiter has a very sharp knee and would work with any input voltage.<br/><a rel="nofollow" href="http://www.uchobby.com/index.php/2006/11/12/current-limited-pc-power/">http://www.uchobby.com/index.php/2006/11/12/current-limited-pc-power/</a><br/><br/>The circuit you show here would limit the current, based on the beta of the pass transistor, I dont think it would have a sharp cut-off.<br/>
Your design continues to pass the full limit current into a short circuit. This one will pass only the current through the red LED into a short circuit. Your design has a variable voltage drop (resistive) upto 600 millivolts. This one has a constant and small voltage drop until the onset of limiting. Minor points, I am sure. But on these two points, I think my design is better.
Is this to be plugged into the USB port?
It has to be plugged into the power connector for the floppy drive.
About This Instructable
34,345views
32favorites
License:
Bio: Hi. I'm Chandra Sekhar, and I live at the southern tip of the Indian subcontinent. I'm interested in building small one-off circuits around ... More »
More by neelandan:Wireless L E D 9V battery case for projects Stereo amplifier, dead bug style
Add instructable to:
