3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PC Rapid Fire
Step 3Customize Code
Customize Code
The first two lines in the program define what you press to start, stop, and exit the program.
HotKeySet("!x", "ToggleSpam")
HotKeySet("+{ESC}", "EndSpam")
The bolded and italicized text in the above code are the hotkeys, and can be modified to suit your preferences. Some explanation is in order, I sense:
! = Alt
x = X
+ = Shift
{ESC} = Esc
Alt+X is easy to press, because in most FPS and 3PS games, your left thumb is already on the spacebar for jumping, so this allows for easy access. Obviously, if you are left handed, or are using a customized keymap, you'll want to change this. Every key is defined here, in the AutoIt documentation
2 comments
Aug 21, 2009. 11:49 AMsevir says:
Unless I'm mistaken, and I probably am, Autoit and Autohotkey (Ahk) use the same language. So I could use this with Ahk, given little code augmentation, right?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Junkyard John
