This simple script, will update a .txt file every time your computer is switched on with the User Account name, day, time and date so if you suspect anything just open the log file to see if you were right.
This script saves the file as C:\Startup-Log.txt but you could easily edit the script to somewhere different with a different name if you prefer.
To make this work Just copy the Script file to your startup folder in the All Users\Start Menu and the windows script host will do the rest
( C:\Documents and Settings\All Users\Start Menu\Programs\Startup ) this one for all users which includes 'Guest'
'Anti Snooper
'Startup Logger
'By Dean Potts
Option Explicit
' Various Variables
Dim FSO, objFolder, objtxtfile, objFile
Dim logpath, logfile, logtext
Dim Action : Set Action = CreateObject("Wscript.Shell")
Dim User : User = Action.ExpandEnvironmentStrings("%UserName%")
Dim Days(7), MonthDays(31), Months(12), Hours, Minutes, MyTime, D, DD, MM, YY
' Day Names
Days(1) = " Sunday "
Days(2) = " Monday "
Days(3) = " Tuesday "
Days(4) = " Wednesday "
Days(5) = " Thursday "
Days(6) = " Friday "
Days(7) = " Saturday "
' Month Names
Months(1) = " January "
Months(2) = " February "
Months(3) = " March "
Months(4) = " April "
Months(5) = " May "
Months(6) = " June "
Months(7) = " July "
Months(8) = " August "
Months(9) = " September "
Months(10) = " October "
Months(11) = " November "
Months(12) = " December "
' Fancy Numbering
MonthDays(1) = " 1st "
MonthDays(2) = " 2nd "
MonthDays(3) = " 3rd "
MonthDays(4) = " 4th "
MonthDays(5) = " 5th "
MonthDays(6) = " 6th "
MonthDays(7) = " 7th "
MonthDays(8) = " 8th "
MonthDays(9) = " 9th "
MonthDays(10) = " 10th "
MonthDays(11) = " 11h "
MonthDays(12) = " 12th "
MonthDays(13) = " 13th "
MonthDays(14) = " 14th "
MonthDays(15) = " 15th "
MonthDays(16) = " 16th "
MonthDays(17) = " 17th "
MonthDays(18) = " 18th "
MonthDays(19) = " 19th "
MonthDays(20) = " 20th "
MonthDays(21) = " 21st "
MonthDays(22) = " 22nd "
MonthDays(23) = " 23rd "
MonthDays(24) = " 24th "
MonthDays(25) = " 25th "
MonthDays(26) = " 26th "
MonthDays(27) = " 27th "
MonthDays(28) = " 28th "
MonthDays(29) = " 29th "
MonthDays(30) = " 30th "
MonthDays(31) = " 31st "
' Sort out the Time in 24 hour format
' hours
if hour(now)<10 then
Hours = "0"&hour(now)
else
Hours = hour(now)
end if
' minutes
if minute(now)<10 then
Minutes ="0"&minute(now)
else
Minutes = minute(now)
end if
' Set up the Variables
MyTime = Hours&":"&Minutes
D = MonthDays(day(now))
DD = Days(weekday(now))
MM = Months(Month(now))
YY = year(now)
logpath = "c:\"
logfile = "Startup-log.txt"
logtext = " [Account:" &User& "] " &MyTime & DD & D & MM & YY
' If the folder doesnt exist then create it
Set FSO = CreateObject("Scripting.FileSystemObject")
If FSO.FolderExists(logpath) Then
Set objFolder = FSO.GetFolder(logpath)
Else
Set objFolder = FSO.CreateFolder(logpath)
End If
' if the file doesnt exist then create it
If FSO.FileExists(logpath & logfile) Then
Else
Set objFile = FSO.CreateTextFile(logpath & logfile)
End If
' free the objects
set objFile = nothing
set objFolder = nothing
Const constappend = 8
Set objtxtfile = FSO.OpenTextFile _
(logpath & logfile, constappend, True)
' Write a New Line in the log
objtxtfile.WriteLine(logtext)
objtxtfile.Close
' Finished
WScript.Quit
Too bad that it shows Windows in all its shortcomings:
Initially I could not save it in the
C:\ProgramData\Microsoft\Windows\Start Menu\Programs folder coz i (the adminstrator) had no privilege to do so and I had to ask the administrator (me) about that.
Apparently that was caused by the fact that my harddisk was formatted in XP while I now rund W7 (who would come up with something so ridiculous).
Then The script generates an error in line 110 (Set objFolder = FSO.GetFolder(logpath))
'A required privilige is not held'
I really dont want to be a Windows basher but microsoft makes that really hard
everything they do, they somehow feel the need to over complicate it.
when i first learned to make windows programs i looked through the windows SDK for ways to make them look and act better, but something as simple as drawing gradient background needs over 20 lines of code, that isnt guaranteed to work,
i made a translated script file to turn it into a simple one line code that works every time but it took me 2 days to do it because everything i tried didnt work.
i think they over do it on security too with file privilages, its one of the many many upgrades (or downgrades) that should never of been added.
folder. That is the folder (or at least one of them) that runs the programs it contains upon startup for my Windows7 computer (It's an HP)
Thanks for the great program!
One Question For You:
Where can I learn to understand this programming language? is it a language? where can i find more information about this type of programming? I'm doing pretty good with C++ but this language has me baffled.
Thanks!
Rtty
Try this microsoft scripting reference site as a starter:
http://msdn.microsoft.com/en-us/library/t0aew7h6%28v=VS.85%29.aspx
but you may be better off searching google for vbscript code examples.
i have 5 programming languages that i learned before vbscript so i found it fairly straight forward to pick up, but i think learning by example is the best way for beginners.
heres a few simple examples to get you started.
***** ' Random_numbers1.vbs
Randomize()
x = MsgBox("This Random Number is "& Int((100-1+1)*Rnd+1)&" ")
***** ' Random_numbers2.vbs
option explicit
randomize()
msgbox(cint(100 * Rnd()+1))
' rnd() produces a random decimal number between 0 and 1
' cint() rounds the number
***** ' File_Runner.vbs
'Opens notepad in WinXP
set WSshell = createobject("wscript.shell")
WSshell.run "C:\windows\system32\notepad.exe",1
I am not entirely new to programming.
I also know quite a bit of BASIC for the TI-84 plus calculator. That calculator's basic compiler was what first got me into programming! I even made a few games for it!
I have also programmed in C++ for the Arduino microcontroller. (its an electronics hobbyist tool)
I have only written programs for my calculator and the microcontroller. Creating programs for Windows7 (or any computer for that matter) is entirely new to me. I am starting programming computer programs and text based games in C++.
there are lots of free downloads for it i think if youre interested, very easy to use, just drop things like buttons and other components onto the window and click them to program their behaviour and uses,
quick to get into and alot of people make plenty money too.
Echo %COMPUTERNAME%/%USERNAME% Login At %DATE% %TIME% >> "C:\startup-log.txt"
This produces something like:
MyLaptop/Fred Login At Thu 03/31/2011 8:18:26.24
The output is not quite as pretty as yours, but it works just fine for me.
i like mine as it is invisible and nobody ever see's it running unlike a bat file does but i like your version too for the simplicity.
i recently thought of the code below as a simple reader so maybe you could do an instructable like this one too but a batch file version with a reader, if its something you would be interested in that is.
if you do, let me know and i'll give it a good rating.
@echo off
echo.
echo *************************
echo *** StartUp Log ***
echo.
more < c:\startup-log.txt
echo.
pause
Put an "@" before the command, and the command is not displayed in the window.
How might these people get past "your" passwords?
L
Guest shouldn't be able to access your files though.
It's interesting, but it only tells you that your security is poor. It doesn't tell you what they've snooped on - can you write a script that does that?
L
The origional concept was to indicate that the computer had been used since you were at work or out shopping and so on.
i'll look into possible future extra features for this script.
The "what" would be interesting, but I don't know the script myself...
L
Personally i dont like event viewer because theres too much information to root through before you get what youre looking for.
I think microsoft likes to over engineer software to make things look complicated when they dont need to be.
Thats my thought on that anyway.
This also covers people who sign in as guest.
If there are any other problems that need mentioning, that you know of, please let me know and i will make another update.
