Step 3Now the hacking part
iImage Information
Now that you are in the save folder you should see the files that hold what you are looking for, but before you change the files you should make backup copies of all save files just in case you mess up (HIGHLY RECOMMENDED). after you have done that click the file to open it. the cannot open file should open up. in that window click select a program from a list, then click ok. once you have done that find Notepad and select it then click ok to open the file. once open there should be lots of readable text that you may understand by playing the game (ex big monster level=0 life+10 speed=5) try adjusting the numbers to give that character an edge don't set the numbers too high or the game might not work. many other things may be accomplished too like unlimited money, all items, and much more. once you are done with the file then save it DO NOT CHANGE THE EXTENSION OR THE FILE WILL NOT WORK! after you save it find out if the file works. to do this run the game and load the file you have modified. if the game runs, and you have everything you changed then it worked, on the outer hand if the game crashes then there is a problem. the best way to fix it is to replace the file with the backup copy and start over. (This Process may only work on older games)
Hacking to your advantage may be considered cheating, but it sure brings life back to a dead game.
H4x0R's gaming motto "If you can not beat a game, then modify it in your favor!"
this is my first Instructable i hope you like it!
