Well i made a Binder... its quite heavier than a regular binder, but its also stronger and looks kind of cool.
For this project i used the following materials
Tools:
Pliers
Wire Cutters
a Knife *
soldering iron
screw driver
a "dremel tool"
a paintbrush (mainly for cleanup or dust-off work)
Materials:
PCB boards **
a Regular cheap Binder (if its used even better, free stuff rocks!... make sure it still works tho)
2 Screws with their nuts (around 0.5" long)
Contact cement ***
a sheet of foam ***
a bunch of jump rings (small rings used mainly to make Charm Bracelets)
*necessary to cut foam and pry stuff off your PCB, anything that does this job will do
** as big as you can get em, for this project you will need at least 2 sheets (11.5 " x 10.25") and 1 (11.5" x 1") minimum
*** Optional but you may decide to use Them in the end (it protects the back of your notes and also gives a padded support)
I have been asked where did i get those huge PCB's here is my response: (if you know the name or kind of the equipment im talking about please comment, so others know where to look :)
Well im not sure what it was, there were 2 huge metallic boxes (the kind you put on a rack thing) On the front one reads " COGNEX 2000 vision systems" the other one reads "Turbo HR+ ESI vision products" on the back both have around 4 camera outputs and the second one also has some serial ports marked "SIO"
i found this picture of one of the PCB sources
Box 1
i assumed they were some part of a closed circuit "surveillance system"... basically when they throw away stuff at the electronics department @ school they let us take what we want XD
UPDATE!!! googfan said he found some Server PCB's that are quite large, hope it helps
SAFETY FIRST! please! when using a cutting tool, or when you are prying things off your board wear eye protection, and cover your nose, i don't think PCB "sawdust" or solder fumes are good for your health, also i had a few close calls before i decided i HAD TO use the glasses
Remove these ads by
Signing UpStep 1Design
First of all measure your Old/Cheap Binder, you will need to know the size of each panel (from now on i will call them Front, Side and Back panel) as well as the placement of the "clamp" (thanx to technodude92) when i say placement i mean to check the location of the bolts that hold it to the back panel or side panel (depending on the binder you want to make)
i wanted to make it bigger
cheap/free old binder
front and back: 11.5" X 10.25"
side: 11.5" X 1.5"
My Binder:
front and back 12.5" X 10.5"
Side 12.5" X 1 5/8"
while you are measuring consider how the board looks, is there a component that stands out?, would it look better as a side panel or front panel? if i cut it this way this component has to be desoldered or cut in half?... be creative
Awesome project, great idea. I love it.
