Introduction: PCB Design of LED's Blinking Using 555 IC
HELLO
In this instructable i just gave blinking led's circuit and pcb layout
if you have any doubt on any steps just go through my previous instructable
PCB Design With Simple and Easy Steps
or else go through the video attached to it.
Step 1: Circuit Diagram
Draw the circuit diagram
Step 2: Verifying the Output
In this step just run and verify the output like led's will blink...
Step 3: Try This
you can also replace the IC with DIP socket ....
Step 4: Adding Signature
This is new one ....
you can also add your signature on the PCB board
Step 5: After Autorouted
Here you can see the auto routed circuit image ....
Step 6: Creating Power Plan
in this step we are going to create power plan for ground
just click on create power plan then on window will pop up in that you can select where to the power plan should be placed
you may select either copper top or copper bottom then click ok
Step 7: 3D View
Here is that the clear 3D view
just enjoy .....
Thank you see u all soon
Epilog Challenge 9
