I take no credit for the design - I am simply posting the information for others to share.
Note that the drill pivots slightly as it lowers, but this should not be a problem for thin material (such as PCB's).
And a big thank you to Ken for the original idea
Remove these ads by
Signing UpStep 1Gather Materials
- base
- back support
- two arms
- front piece
- four hinges
The wood I chose was from an Ikea shelf system, approx 18mm (3/4") thick, and 90mm (3 1/2") wide. I had several candidates for the wood, but chose this because it was slightly wider than the hinges, and also sturdy.
I guessed the sizes, making the base longer than the arms. Approximate sizes are:
base - 450mm (18")
back - 270mm (10 1/2")
arms - 310mm (12")
front - 90mm (3 1/2")
Myself, I'm looking for more of a "full-size" drill press. I'm thinking of making it from metal pipe, instead of wood; but this is causing some other headaches. Good luck with your project!
for those with issues with with attaching the drill to the wood, large diameter hose clamps (2) work a treat =)
I personally used longer pieces of wood, and this definately helped reduce arc in the usable range of the press.
Great, cheap build for students like myself.
I used 1x6 board because that's what I had.
There is almost NO ARC in the drill path (travels almost perfectly straight up and down). A few things to note here:
1) I haven't done the geometry, but because I used 1x6, and therefore made the front piece 6 inches instead of 3.5" (to keep it a square) maybe I have much less arc than the original???
2) make sure the hinges on the back are the same distance from each other as the hinges on the front -- this minimizes any arc!
3) While there is no arc the dill still moves horizontally (towards/away from the back board), but in the short distance traveled during a PCB drilling this movement is so small you can't see it.
I made the back shorter and installed a spring BETWEEN the arms (other end connects to bottom arm).
About holding the drill straight -- I put four eye-bolts next to the drill (2 per side) -- wire goes across them much like your original.
To keep it pointing straight down I did this:
1) Wrap the drill in aluminum foil.
2) Line up the drill and inject some hot glue on the left and right side of the drill (so the glue is touching both the drill-foil and the board).
3) Once the hot glue cools enough to keep it's shape I remove any foil that isn't stuck to glue.
4) Oh yeah -- I also put some glue at the top and bottom so the drill can't slide up or down.
The foam-instead-of-spring idea sounds good -- I had to put extra tension on my spring because the arm was slamming down once it went through the PCB.
Once again -- thanks a million!!!
Lam
I made this one last year:
http://www.instructables.com/id/%2430-High-Speed-PCB-Drill-Press/
but I got a little out of control -- modeled it in a CAM program (CATIA, at work), did it in 80-20, etc.... so it was kinda spendy. I think I just did it for the fun of it. Truthfully, I mostly just use my Dremel Drill Press, it's "good enough for government work" and it's extremely portable & easy to set up & tear down.
The nice high-speed pneumatic 80-20 press is professional, but it's overkill for my needs & the wife doesn't like the (relatively quiet) compressor running in the family room!
Great project!
