iImage Information
As you can see from the picture. This is my DIY etching machine.
I constructed this etching machine almost 10 years ago(1998)...
Following step is the construction detail..... Enjoy...
Step 1Detergent container being use as etching container... (Recycle...)
iImage Information
As you can see from the picture. I am using recycle detergent container to do the etching. The detergent container measuring L=25cm X W=13cm X H=6cm. By using pen knife, cut out some of the area which is large enough for you to place your PCB into the container. Please leave some space on the edge of the container where you don't want your etching solution to spill out during etching process. This is important because the water will be disturb vigorously.
and i find it hard to believe that you are putting down this man, when you yourself haven't even heard of PCB etching, when if you type it in that search box up there, you will find many instructables on it.
