now I am going to describe the making process step by step
Remove these ads by
Signing UpStep 1: Stuff material
so ...... lets Make it ....
Material use :
1. Plastic container to hold the unit (pump and etching liquid) -- Please make sure you only using the PLASTIC / RESIN / FIBER GLASS material otherwise if you use the metal thinging will cause you a disaster (since the plastic is corotion proof)
2. Mini DC pump -- this is the main unit to make this machine operated.
Basicly you can use any type of the pump, but again MAKE SURE the material is PLastic, NOT METAL. --- WILL BE EXPLAINED IN THE NEXT STEP
3.PLASTIC PIPE TO DISTRIBUTED THE LIQUID ECTHAN
4. OFF COUSE YOU WILL NEED A 12V POWER SUPLY (OR DEPENDING YOUR MOTOR SPECIFICATION) TO MEKE YOUR MOTOR RUNING AND PUMPING AND DISTRIBUTED THE ETCHAN LIQUID FOR YOU
Visit Our Store »
Go Pro Today »
photograpic pos method help newbi
My guess is that whatever you using is getting washed away by the feric chloride during the etching. There are a couple of thing you can try, heating up the feric chloride if you don't already do that. This will speed up the etching process give the ink less time to be washed away. Or find other ink to use.
as for my etching machine, i build two, one has a rocking motion using gear motor and the other one, almost the same as this one but i used aquarium type aerator pump..
i am a sign maker i need to know how to make sing bored on copper with etching by using bcp way or anther ways to do it .
thank you
and t.c
Use thin aquarium tank as the chamber; use 1 of the pumps to circulate the FeCl through the tank (and for that matter through a reheater trough to maintain temperature and stabilize the rate of etch). Also, the aquarium tank would allow you to see more of the result as it happens for either single or double sided boards...a thermocouple on the tank could show a digital readout of the temperature...and the same circuit could have a settable etch timer to countdown and play a sound when the etch is finished. (No standing over it to wait).
And if you really wanted to automate it...place the whole assembly on a slide frame and have an upper safety frame lower and raise the board in and out of the tank...no standing near fumes...no accidental proximity splash hazard.
I'd draw this...but it's essentially been done before...somewhere....anybody remember where? Your idea is cheaper, sure..but what about the result?
AQUARIUM tank will be a good idea too, as you are wrote, we can add a such as an aquarium heater to keep the temperature of the liquid warm and this will be slightly improve the process,
as mentioned you dont have to sit and wait in front of this working process, you can just leave it and came back later to see whether the process is done or not,
but you can get a freee for this methode, just do the process under the blazing sun :) and you will got the cheap and cheerfull way :)
as I wrote bellow, will need less than 5 minutes if you have a brand new FeCl combine with warm water, but if you have an old mixing liquid (with regualr / cold water) this can be more than 10 minutes.
back to the original idea, we keep the cost as low as possible and big possibility to use a recycled material that not use in your place, but if you may disobedient this idea than up to you to get your crazy idea and spent more money to build this.
just use a masker if you are prety close with the working liquid , this will guaranty your safety.
conclusion:
Horizontal immersion = Moving the fluid is better
Vertical immersion = Air bubbles is better
warming the acid does help make things faster but do this only on well ventilated area because of the fumes evolved
if you are going to make your electronic project from zero, you will understang this machine function.
this machine saving your time and money to develop a pcb and make you more productive
just gogle about pcb making process and you will understand
cheers
because when I saw it the first I said something like holy ............
But know it's clear.
Thanks and keep the god job!
i have a few little pumps laying around i might try to put something together later
but to keep it as simple as possible i did not adding such as other timer / automation circuit to handle how long should it take / operation (MANUALLY), but actually is you positioning the tank a bit sideways, you will see clearly whether the process is done or not, as my attached movie above.
second pump to the storage container is absolutely great idea, so we don't have do this manually, if you have a spare motor pump will be no problem at all.
in my case, if i use the brand new FeCL mixed with warm water, will be take not more than 5 minutes to do the clean copper etch.
just give a try for your though, this will improve this instructable.
cheers
