loading
Step 8: Final steps
Tin all the parts where a component is going to be soldered. Then solder all the components in place and clean the remaining flux or resin.
If you liked my instructable, please vote me for the Laser Epilog challenge.
<p>where do you get the acid thingy.And will inkjet printer works?</p>
<p>Hi,</p><p>Inkjet printer will not work (different kind of toner/paint, different way of printing etc.). Only laser.<br>Etching solutions is usually available at local electric shops (where normal components are available: resistors, leds or even plain PCB boards). Note that it is not available for on-line orders in most countries due to postage restrictions.</p>
<p>Do you know if bubble jet ink will work?</p><p>Thanks</p>
I think it won't, tones is a polymer composite that melts onto the paper during the printing (or transfer) process, ink doesn't work that way.
<p>Thanks a lot! It was really geniune. I was looking for a copper board to buy; Is there any thickness recommended??</p>
<p>Love this guide. As someone who's started dabbling in DiY/hobby tech design stuff this is really helpful. Also works well with some other info I've been pouring over like this: <a href="http://www.elex.co.nz/services/pcb-design/" rel="nofollow">http://www.elex.co.nz/services/pcb-design/</a> . Though I think it's about time I pulled my head out of books/guides/texts and started cutting some copper :P Anyone have any links to other resources or step-by-steps I should use too?</p>
<p>I use this method for a long time already, goes perfect. Still, i observed something odd: when I used the printer ink that came with my printer it went well. after I bought new brandless ink the toner transfer didnt go so well.<br>Now I am not saying you shld buy expensive ink, on the contrary as I have only tried it twice since I bought new ink. But I am wondering if others have the same problem.<br>Maybe it is just a matter of adapting the heating, as my new ink seemed to melt and smudge</p>
<p>Electrolyte solution is just CuSO4 / NaNO3 = 1 / 2</p><p>CuSO4 is bluestone and NaNO3 is cooking salt. Any 20% peroxide! )) The process is smooth, quiet and pretty quick (up to 30 min for 20 C deg.)</p><p>Here is an article in Russian - some further details and vivid pictures: <a href="http://easyelectronics.ru/travlenie-pechatnyx-plat-mednym-kuporosom.html" rel="nofollow">http://easyelectronics.ru/travlenie-pechatnyx-plat...</a></p>
<p>&gt; CuSO4 is bluestone </p><p>Also available as root remover for drain pipes. </p><p>&gt; and NaNO3 is cooking salt.</p><p>Please don't invite me for dinner. </p>
&gt; Also available as root remover for drain pipes.<br>Well we use ax just like as our ancestry did ... or air compressor cleaning + chainsaw then = in most complicated cases. )) <br><br>And our bluestone is good for tomatoes' cure for many blights (in mixture with lime and water).
<p>&gt; ... antiadhesive oven paper works the best!</p><p>I'm sure THICK GLOSSY PAPER for INKJET PHOTO PRINTERS works MUCH better than your oven paper. Cause glossy layer impregnated and baked into melted toner traces gives much more thick and robust mask than naked toner itself... Try and compare!</p>
<p>I have been using this same basic method for years, and it works great. This is very good write up of the method. This old dog learned a new trick ... The Paper!</p><p>The paper that I used in the past was the cheap photo high gloss print paper from Staples. After testing many other kinds this is what I found worked best BUT not all the time.</p><p>I will buy some &quot;Parchment Paper&quot; tomorrow! This old Dog wants to try out this new bone!</p><p>Thanks, Great Job!</p><p>BTW: I use 40% Muratic Acid and 60% Hydrogen Peroxide. I buy the Muratic Acid anywhere they sell building supplies. It is used for both drain cleaning and brick cleaning. I buy the Hydrogen Peroxide at a beauty supply store. I use 20% concentrate. </p>
oh and where might i find hydrochloric acid
hydrochloric acid is normal pool acid found in general groceries stores
<p>Also known as Muratic Acid (aka HCL). Available at any big box home improvement store or any large discount store. Look the pool maintenance section.</p>
How do you line it up for a double-sided PCB?
<p>I line up both side by putting a bright light behind the papers and line it up visually. Then i tape the papers together then just slide the board in between before ironing.</p>
I've seen that people print 4 dots out of the circuit, they hole them, and hold them in place with something trough them. But you have to make sure that the design of both sides match correcly.
what do you use to design your PCB?
For a first attempt, play with PCBExpress (Google it). It's FREE. There are other sources for free design software, just search a little.
PCBExpress did not have design software but ExpressPCB did. testing it out. thanks for the lead.
Correct, mybad. Senior moment :)
I've used photoshop, but there is specific software to do it.
<p>According to step 4 Removing the paper. I hold move transferred board into vinegar bath, hold it in for few minutes then paper goes out very easy.</p>
<p>I used to do this with my boards, but the cost and the error rate can be a problem from time to time. Now, I just use OSH Park and I get 3 copies of small boards for less ten dollars including shipping. Three boards of about 2x5 cost about $50</p>
It may be convinient, but $50 is more than the whole budget i have for most projects.
i didnt find copper plate where exactly they available?
<p>They're sold on ebay, just look for copper clad boards.</p>
<p>It worked for me but everytime i had a fallure that only 10-12% toner is not getting transeferred onto the board ..... it has happened thrice now and the portion not transferred is the same everytime ... what could be the possible reason behind it ? do give a solution</p>
Now i use parchment paper to make the circuits with the best results, just print the circuit on the anti-adhesive side. No toner gets stuck in that paper.
<p>can u plz give the concentration of chemicals for etching solution ?</p>
It can vary, normally i aim to make a 50-50 solution, but i haven't experimented for optimal results.
What is the mix of acid to hydrogen peroxide, or is it a product off the shelf?
<p>Generally 30% concentrated HCL and 2-3% conc H2O2 in equal quantities will etch the board in 1-2 minutes. </p>
I use 1 part HCl to 2 parts H2O2. There is a shorter shelf life for this mixture, it generally doesn't last long unless you 'regenerate' the etchant solution. Search online if you are interested in this ;) I would still recommend this process over other etchants.
there are many etching solutions available from most electronics supply houses. even the radio shack has an entry. some are shipped as a powder for safety reasons. you may find some with which you can live. good luck <br>
This mixture produces chlorine gas once mixed, and to bottle a product that expands producing poisonous gases is not the a good idea.
thanks i will be trying this out
<p>on the anti-adhesive baking paper - is that the same as &quot;Parchment Paper?</p><p>http://en.wikipedia.org/wiki/Parchment_paper_(baki...</p>
Yes, i think so.
<p>FWIW - I just tried a test print on some Reynolds and Reynolds parchment paper with an HP Laser Printer. When R&amp;R claim non stick - they really mean it. You can actually rub the toner off it. I am going to try and iron a pattern on a board - I will be very, very, careful not to smudge the print.</p>
About This Instructable
248,189views
1,505favorites
License:
Bio: I love electronics and all about DIY.
More by pinomelean:IN-12 nixie clock Li-ion battery charging Mini line tracer
Add instructable to:
