Remove these ads by
Signing UpStep 1The Starting Point
I looked about the house for an acceptable connector, hoping that I'd find something with the same pin spacing, but it is an uncommon layout and spacing. I decided that the best route then would be placing the connector on the exterior of the laptop, and hopefully adding in a breakaway feature to prevent damage from similar accidents. Ultimately I settled on a lego technic wire, as it pulls apart under stress, can handle the amperage involved, and is a modular low-cost solution. (Keeping in mind that they aren't liable if your project catches fire or other harm befalls it.)
Tools and Supplies needed:
Tools:
Needle nose pliers
Jewelers screwdrivers in a variety of sizes, Phillips head.
Flathead jewelers screwdriver or similar prying device.
Soldering iron with fine tip.
Sharpie.
Labeling or masking tape.
Razor blades or wire stripper.
Lighter.
Diagonal cutter.
Supplies:
Shrink wrap tubing, in sizes appropriate for the wire you are using.
Wire, capable of handling 2.5 amps @ 16v DC.
Solder.
Lego wire.
De-soldering braid or equivalent.
6
comments
Add Comment
ll.13
says:
gmjhowe
says:
Add Comment
