It's important to protect your eyes from splashing chemicals and stray bits of wood or metal but safety goggles always look so you might as well look dorky in safety goggles of your own making.
The whole project should take under 45 minutes, minimal tools/materials and will result in some very comfortable goggles fitted to your specifications.
For making your own PET SAFETY GOGGLES you will need (most of) the following:
  • A knife and/or scissors
  • One PET bottle
  • Some tape (I used grip tape but duct would also work)
  • Matches/a lighter/candle
  • Some wire
  • Some ribbon or elastic strap.
Start by cutting the PET bottle into a cylinder, which is the only part you will need. Uses for the top and the bottom of the bottle are up to you.
*I will use the top as a funnel and the bottom keep put a plant in.
Step 3: DIVIDE
Cut the cylinder once so that it can be opened up completely. Place it over your eyes: You will need at least 2in or 5cm more than what reaches from your left to right temple. Trim it if you need to.
For me, a 1L PET bottle was the perfect fit and I did not have to trim it at all.
Step 4: EDGES
Cut 4 slices (about 1in or 2.5cm) into the PET plastic so that you can fold edges onto themselves, as if you are making half of a box. Where the edges overlap, put two small holes in the plastic with your knife/scissors and join them with a short length of wire. The PET plastic will still want to roll together but you should have clearly defined sides now.
Step 5: SOFTEN
Use your lighter or the matches/candle to slightly melt the edges of the PET plastic. By doing this on the corner edges you should be able to get the plastic in more of a square shape and by doing it on the long sides you will be able to make the form more fitted to your face shape.
For extra comfort I suggest covering the edges with tape. I used an athletic grip tape I found but duct tape would also work very well and comes in a variety of colors.
Step 7: STRAP
For the strap I used some pink ribbon (because it matched the tape) but you can use some elastic, other colors of ribbon or string.
Poke two holes in the short sides of the goggles and slide a length of the strap material through them so that you have two bits of strap which you can tie behind your head.
Because of the springy nature of the PET plastic, when you tie the straps in a bow behind your head, the plastic will pull back and create a comfortable amount of tension on your face so that the goggles don't leave marks (depending on how tight you tie it) while they still stay firmly in place.
Step 8: SAFETY
Now how dorky you look while being safe is completely in your own hands. Modify your new PET SAFETY GOGGLES how you like...put some LEDs in them if you wish to be safe at night (and extra nerdy).
For more, check out:
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    This is a good idea FOR SOME APPLICATIONS!
    PET is not really rated for impact resistance so these goggles are not good for protecting against anything high velocity. They would be a pretty good idea for low velocity stuff like Nerf or marshmallow gun fights. Not a good alternative for shooting goggles or impact rated goggles intended for airsoft or paintball. Also good for light particulates like sand, dirt, mud, sawdust and powder, but I would NOT trust my safety to them when working with metal, especially around hot chips and high RPM tools. PET heat warps and discolors fairly easily so these would not be good for use in heat blast areas like foundrys or near furnaces. Simple manual work like sawing or filing would probably be fine. For liquids, PET is fairly versatile and resistant to many low strength solvents. PET is not optically clear so visual distortion will be a problem at times so these would not be good for high speed uses like driving. Also, PET has no scratch resistance so it would become easily scratched. DO NOT USE GOGGLES LIKE THIS IN ANY PLACE WHERE OSHA/ASTM GOGGLES ARE REQUIRED! THIS IS A MASSIVE VIOLATION.
    All that said, PET is a pretty good plastic for light duty protection and it is very cheap. Might I suggest going to a discount store and buying one of their comically large 3 Litre bottles of terrible off-brand soda? Those bottles normally have flat sides so you can get a pretty good sized sheet of clear plastic from them. Also, the green plastic used in some lemon-line soda bottles is really neat to make costume goggles out of.
    Good concept, just needs a disclaimer. Happy Halloween!
