3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PIC18F Based 6 Channel DMX Transmitter
Based on AN1076 - "Using a PIC® Microcontroller for DMX512 Communication". Modified and added to Microchip's code to use 6 AdC Channels for 6 channels of DMX data and the ability to offset its starting address via a 9-position DIP switch.
Designed to demonstrate a simple DMX transmitter and to test DMX Controlled lights without having to adjust their address or change anything in a prepared show if using DMX Software and USB DMX device.
It is written in Assembly and utilizes a PIC18F24J10. A bit odd as it's voltage input is 3.3v and it requires a low ESR capacitor to ground on one of its pins. I am sure the code could be modified to work on any 18F PIC with a EUSART.
There is no PCB layout, it is easy enough to construct point to point on perfboard.
Please Take a look at AN1076  From Microchip and the PIC18F24J10 Datasheet.
I apologize about my images as my camera decided to crap out with this and another project worth of images on it, so I did my best to recover and recreate them.
*UPDATE:
V2 - Updated the schematic to show the potentiometer hookup.
V3 - PIC Transmit pin was hooked up to the wrong pin on the SN75176, fixed, should be pin 16 on the PIC connected to pin 4 on the transceiver. A pretty big mistake, sorry to anyone that got screwed up by it.
DISCLAIMER: Not responsible for any damage or injuries resulting from this instructable. Damage to DMX Devices is possible if this transmitter is not built correctly.
Step 1Supplies
Parts:  (all ICs are DIP spacing)
- 18F24J10
- SN75176A - RS-485 differential bus transceiver
- 28 pin socket
- 8 pin socket
- 10 position DIP Switch
- 3.3v linear regulator, TO-220
- 16 mhz Crystal Oscillator - I used ECS-2200BX-160
- 8 pin socket
- 28 pin socket
- 6x slide or dial Potentiometers
- Female XLR, i use panel mount
- Male XLR, not really needed
- 2x 10 1/4w resistor, R3 & R5
- 100 ohm 1/4w resistor, R2
- 120 ohm 1/4w resistor, R4
- 10kohm 1/4w resistor, R1
- 10uF low ESR cap, less than 5 ohm, but most caps can still work,C1
- 2x 1uF electrolytic capacitor, C3 & C4
- 0.1uF disc capacitor, C2
- Perfboard
- Solid strand wire
- 5v @ 500ma PSU
- DC Power Jack, I used a 2.1mm that matched my 5v power supply. Buy PSU with Matching Jack
-Enclosure, or parts to build one.
Tools:
- Solder
- Soldering Iron
- Pliars
- Diagnal Cutter
6 comments
Jan 12, 2012. 8:58 AMSimonTunes says:
Sorry, how can I connect the male XLR port?
Anyway, this is a very interesting project! Can I buy a KIT with the components? ;)
Thanks!
Sorry for my bad english.. I'm Italian! :D
Aug 8, 2011. 5:03 PMasmodi says:
Project is cool but Can you use USB connection with this project?
Jan 25, 2011. 7:05 PMPS118 says:
Can't really read the schematic. Could you please add that and possibly the firmware as downloads?
Thanks. :)
Jan 26, 2011. 11:23 AMPS118 says:
Cool, thanks!
Jan 20, 2011. 9:22 PMjoejoerowley says:
Pretty badass. What's the plan for this guy? Hooking it up to an ion or something? haha
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
