PIR Controlled Buzzer Using Arduino
Published
Introduction: PIR Controlled Buzzer Using Arduino
About: I am an electronic hobbyist on Arduino, Photon, Raspberry Pi and common electronics.A passionate cook.Any assistance in electronics and web development feel free to contact me at appytechie.at@gmail.com.
Hello, In this Instructables let's learn to control a buzzer with a PIR interfaced with Arduino.
Let's get started!
Step 1: Components Required
Components required for making this projects are:
  • Breadboard
  • Arduino Uno
  • PIR sensor
  • Jumper wire
  • Buzzer
Step 2: Adding PIR Sensor
PIR connection is as follows:
  • The VCC pin of the sensor is connected to the positive railing of the breadboard
  • The GND pin is connected to the negative railing of the breadboard
  • The signal pin is connected to the digital pin of the Arduino board.
Step 3: Buzzer Connection
  • Solder the pins of buzzer to male to male jumper wire
  • connect one of the pins to pin 2 of the arduino board and other to ground connection of breadboard.
Step 4: CODE
Step 5: OUTPUT
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
