PIR SENSOR WITH ARDUINO ACTIVATE STEPPER MOTOR
16,132
48
12
Published
Introduction: PIR SENSOR WITH ARDUINO ACTIVATE STEPPER MOTOR
ACTIVATE STEPPER MOTOR USING MOTION SENSOR
Step 1: PIR WITH ARDUINO ACTIVATED STEPPER MOTOR
Hi this instactable to rotate stepper motor foreword and backward when pir read some motion.
Step 2: PART REQUIRE
1-ARDUINO UNO
2-PIR(HUMAN MOTION SENSOR)
3-L293D (MOTOR DRIVER)
4-UNI-POLAR STEPPER MOTOR(28BYJ-46)
5-SOME WIRES
Step 3: STEPPER AND PIR
Step 4: CODE
Arduino with PIR motion sensor
activate camera motor projects
Writes by Engineer Mohanad Hameed */
#include //include stepper library int led = 13; // the pin that the LED is attached to
int sensor = 2; // the pin that the sensor is attached to
int state = LOW; // by default, no motion detected
int val = 0; // variable to store the sensor status (value)
int in1Pin = 12; //the pin that the phase 1 is attached to
int in2Pin = 11; //the pin that the phase 2 is attached to
int in3Pin = 10; //the pin that the phase 3 is attached to
int in4Pin = 9; //the pin that the phase 4 is attached to
int step_num =700;
Stepper motor(64, in1Pin, in2Pin, in3Pin, in4Pin);
void setup() {
pinMode(led, OUTPUT); // initialize LED as an output
pinMode(sensor, INPUT); // initialize sensor as an input
pinMode(in1Pin, OUTPUT); // initialize in1pin as an output
pinMode(in2Pin, OUTPUT); // initialize in2pin as an output
pinMode(in3Pin, OUTPUT); // initialize in3pin as an output
pinMode(in4Pin, OUTPUT); // initialize in4pin as an output
motor.setSpeed(300); //speed of the motor }
void loop(){
val = digitalRead(sensor); // read sensor value
if (val == HIGH) { // check if the sensor is HIGH
digitalWrite(led, HIGH); // turn LED ON
motor.step(step_num); //rotate the motor foreword
delay(1000); // delay 300 milliseconds
motor.step(-step_num); //rotate the motor backward
delay(300);
if (state == LOW)
{ state = HIGH; // update variable state to HIGH
else {
digitalWrite(led, LOW); // turn LED OFF
motor.step(0);
if (state == HIGH) {
state = LOW; // update variable state to LOW
Step 5: CIRCUIT
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    12 Discussions
    OK.We can use it To control the camera So that the camera is moving toward the persons Or it can be used to open the door and so on .
    CAN i get a right code?
    Hello Friend!
    The code line 4 must be some mistake because it is showing the following: #include expects "FILENAME" or <FILENAME>
    Any tips? Thank you
    Hi
    Please see this line
    there is flower bracket is diseble so enable the flower bracket code is working fine.
    if only 5V can motor move?
    the code has some error, some solution
    error in code says that 'Stepper' does not name a type
