loading
I made this for my Nikon lens.
You should choose different size of bottle for the size of your lens.
Is waterproofable with innertube.
Step 1: YOU NEED
MATERIALS:
_2 bottles of the same water (better if with flat bottom);
_spongy material;
_zipper;
_dental floss.
TOOLS:
_scissors;
_safety pin;
_needle.
Step 2: CUT PLASTIC BOTTLES
cut the plastic bottles: one a tiny bit longer that your lens, the other 1 cm on top of were it start to become straight. (see photo)
Step 3: MAKE HOLES WITH SAFETY PIN
make holes with the safety pin  all around the edge of the 2 pieces of bottles. 1/2 cm far apart.
Step 4: PUT ZIPPER
sew on zipper with dental floss (i used it 'couse is really strong), using the holes you made before with safety pin.
Step 5: CUT SPONGE
cut the spongy material: 2 circles of the circumference of your bottle and one rectangular piece that will fit the side part of your bottle.
Step 6: PLACE SPONGE
place the 2 circles on the bottom of the 2 bottles, and the rectangular piece all around the side. you can glue them to place (mine just hold themselves in place).
Step 7: DONE! WATERPROOF IT!
you are done! you can waterproof it if you want: cut an innertube in half and sew it like a ring of the size of your bottle circumference (it should be really tight fit) , place it all around  the zipper (this will work only the side of your bottle are really flat, and if you make it tight...anyways I don't want to feel responsible for the safety of your lens!).
<p>thanks for your i structible. Inspires me to have a go.</p>
nice! how long is the zipper?
Thanks! <br> The zipper should be of the same measure of the diameter of your bottle, so it depends from the size of the bottle that you will choose. Thanks to pointed that out.
I like it
Thanks <br>
Very nice! If allowed a suggestion, you could further increase its waterproofness (is that a word?) by running a small bead of silicone between the inner tube and the bottle before stitching it on. That should eliminate any possibility of a leak between the two surfaces. <br> <br>These would come in handy at the beach for items you didn't want to get wet, e.g. cell phone, wallet, lens cloth, matches, etc. Glue the top of the bottle to the bottom, drill a hole in the bottle cap, put a loop of Para cord through the hole and you have the perfect attach point for a carabineer. Could be used anywhere, e.g. bike, bag, belt, etc. <br> <br>Great instructable! Thanks <br>
thanks! cool advice! <br>(and yes! waterprufness is a word!)
It's perfect for my new lens, thanks for uploading this!
you're welcome!
To Adam.... <br>This is splash proof. or puddle proof. The holes in the tube will not allow this bottle to go overboard, but dropped in a puddle it will likely stay dry. To improve seal stitching with caulking. Will still need inner tube since most zippers are not water sealed. Hmmmm... What about gluing a zip lock for a better connection between the parts.
thanks!
How waterproof is this? Are we talking like light rain, heavy rain, dropped in a puddle, or over the side of a boat waterproof by your guesses?
sure is by my guess! I don't have any tools for testing waterproofness yet! <br>anyways common sense will suggest me: <br>if you don't wave your lens during a rain but you keep it in your bag <br>it will be waterproof with a &quot;light rain&quot;(intended like 1mm of rain per hour, or 0,2641 gallon per square meter of rain par hour) all the way to a medium rain (4mm of rain per hour , equivalent to 1,0564 gallon par square meter of rain per hour). on hard rain (7/8 millimeter per hour I will may be not keep it in the rain for too long , but I m pretty sure that if you did well the lens bag it will be all right ('cause plastic and innertube are waterproof, and this is not my guess). <br> like I wrote in my instructable it depend on how the shape of your bottle and how tight you can make it. <br>
What a brilliant idea. And made from things easy to get.
Thanks! I m proud of this one!
Very cool! Maybe a waterproof zipper glued to the bottle as well as sewn could also work to make it waterproof. This also seems like a good way to ship a lens (inside a box of course).
Thats a good idea too,maybe more waterproof too.
interesting
Very smart! Much better than the soft and fragile Nikon lens-bags I have!
yes, like the Nikon one I had. thanks!
this is really cool! great use of ordinary household products!
thanks!
About This Instructable
33,968views
355favorites
More by marcellahella:SIMPLE PAPER BOX OLD DRAWER TO SHELF RICE MILK
Add instructable to:
