3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
PLAY AND RECHARGE IPOD USING OLD BOOMBOX - Hints and tips
Step 3HOW TO RESOLVE THE IMPEDANCE MATCHING PROBLEM
Parts Needed:
2 Audio Isolation Transformers - Radio Shack Radio Shack - 273-1380 $2.99
Scrap of perfboard
Okay, here's the biggest hint of the entire mod. In STEP 1, I found a clean line. However, after I wired up the docking connector to test it, the Audio Line Out (Pins 2, 3, 4) Pinout signal was waaaaaay overdriven. I tested it with the headphone output and it sounded fine at about 1/2 iPod volume. However, the volume doesn't work when you use the Audio Line Out from the docking connector. The sound was absolutely gross. Back to the internet for some research I went.
On the internet I ran across some black magic called "impedance matching." Here's a link for some information. http://hyperphysics.phy-astr.gsu.edu/hbase/audio/imped.html Turns out, the Audio Line Out from the iPod is high impedance while the headphone output is low impedance. I figured the cassette tape circuit is designed for low impedance since it sounded fine with the headphone output connected. I needed to figure out how to lower the impedance of the iPod's Audio Line Out. I first tried to insert a simple headphone volume control in between the Audio Line Out and "clean line." All that did was made an overdriven signal less loud but still gross.
Then, I came across this device at DAK Industries. Impedance thingy It takes a low impedance circuit and matches it to a high impedance circuit via an isolation transformer. I wondered if I could reverse that principle.
Back to Radio Shack. I found these audio transformers and bought two of them (one for each channel). I used these "backwards."
I wired and heat shrunk the 8 ohm windings of the transformers to the "clean line" found in STEP 1. The bigger 1K ohm windings I connected to the docking connector (pins 2, 3, 4) Pinout. The grounds can be wired per the diagram. I mounted the transformers on an old piece of old perfboard. Then I modded one of the cassette mechanism brackets to mount the transformers. Lo and behold, the transformers worked! Booya!
Remember I was talking about do-overs? I finished up all the soldering, wiring and reassembled everything. I thought I was finished with the entire project. Not so! I powered up the boombox and eeeeeeeeeeeeeeeeeeeee - audio feedback! When I plugged in the iPod, the feedback disappeared. That meant I had a no load audio feedback loop. Doh! I wanted to drop kick the darn thing. Did I have the courage to tear it all apart to try to fix it? Not courageous, just stupid.
After taking it all apart again, I stripped off the shrink tubing, desoldered the connections and basically started all over. I reconnected it in different configurations. Nothing was working. Finally, I figured it out. Remember those two jumper wires I found on the main board, where I found the "clean lines?" I decided to cut them. Lo and behold, it worked! What I had done is cut out the preamp circuit. The circuit was causing a no load feedback loop.
In fact the sound was better than before. No hiss or humming, very clean. Booya!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:unknownuser2007
